Old 09-04-2010, 05:57 PM
wolffman007 wolffman007 is offline
wolffman007 is on a distinguished road
Default need radio install help
hi all, new to the forum & just bought my ram
01 1500 SLT laramie 5.2 (yeah i know, choices were limited)
i belive it has the infinity system (it has the tweeters in the a pillars?)
i already searched & didnt find an answer
i hooked up the ground, constant 12v & acc & the deck powered on & seemed ok, i did not have any speakers hooked up at this point
shut it all off & connected the right & left front speakers, went to test & now the deck wont power on at
i checked all the fuses, even the one in the back of the deck, all are ok
i checked the pink wire & its not receiving constant 12v (now?) to my understanding it should be
the acc is powering on when the key is on, but the deck still wont power up
i disconnected the 2 speaker wires, cause i know some systems have factory amps that can be a problem (and i read a post or 2 about that)
so my problem/question is
1 is the pink wire supposed to be constant 12v?
if it is where else should i look for a fuse, relay or whatever the problem is
(like i said when i first hooked this up, it was just the 2 power & gnd & it powered up fine)
am i missing something?
thanxs
Wolffy
Old 09-04-2010, 06:00 PM
sobercrew's Avatar
sobercrew sobercrew is offline
Vehicle: 2003 dodge ram 1500 4x4
Color: silver/chrome
Rep:101
sobercrew will become famous soon enoughsobercrew will become famous soon enough
Send a message via Yahoo to sobercrew Send a message via Skype™ to sobercrew
Welcome to forumz i dont know the answer to this the best i can do is say the obvious on checking all wires to make sure they are conneted correctly and no breaks in the wire and also check the fuse on the back of the deck if you have one or under the dash.
Hope this is of help to you and someone will be along soon to give you the answer your looking for
NEW SIG PIC YAY
Old 09-04-2010, 07:10 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Welcome to the Z. Sorry, I don't have a clue on stereo systems, but we do have some experts here. I'm sure they'll drop by with some advice. Here's a link to a post just for audio issues.
http://www.ramforumz.com/showthread....ighlight=audio
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 09-07-2010, 12:15 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site! Sorry I am unable to help, but will bump this thread up so others can take a look
Old 09-07-2010, 03:11 PM
thmike thmike is offline
Vehicle: 2001 Dodge Ram 1500 Ext cab
Color: BLue
thmike is on a distinguished road
your doing this to an after market cd player..cause if you are you should just buy a wiring harnes..its like 5 bucks..saves you all the guessing
Old 09-07-2010, 10:45 PM
i bought a harness to start with
like i said, when i first hooked this up, with just the gnd & 2 power, i had power, but now i dont & i cant find any blown fuses or a relay that might have gone out
Old 09-09-2010, 01:29 AM
projectdodge1500's Avatar
projectdodge1500 projectdodge1500 is offline
Vehicle: 2012 Dodge Ram 1500
Rep:43
projectdodge1500 is on a distinguished road
Default Wiring Harness
I just installed a very nice one in my 97, but I bought the wiring harness and it makes a world of difference. It took me about 15 minutes for stereo and three hours to replace all the speakers, lol.
2012 Ram 1500 5.7-1993 Dodge Dakota 4.3-2012 Jetta-Crazy Custom Scooters
Old 09-09-2010, 07:17 AM
agjames agjames is offline
Vehicle: 2010 , crew cab, 1500
Color: inferno red
agjames is on a distinguished road
I would consider pulling the deck out and bench test it. I am sure the pink wire is supposed to be constant power on acc but there should also be an amp trigger wire. This wire sends a signal to the amp to power on. you may have these wired might be mixed up.
I could check wiring info. did you say this is a 2001 truck?
Old 09-09-2010, 11:11 AM
Color: BLue
i bet some how the radio got shorted..why did you just put the power and ground on to test it? Normally people with a wiring harness just wire everything then plug an play
Old 09-09-2010, 08:30 PM
i already tested the deck, it works
there is NO power to the pink wire, from what i can tell should be constant 12v
UPDATE
I just ran another 12v wire, the deck is now installed and powering up fine, but i dont have ANY sound at all, with the factory or aftermarket deck
yes i have the amp wire hooked up
i havent tore a door apart to check the speaker, but as i have 2 amps & 2 speakers & 2 subs to install, im just going to run all new wire
thanxs for all the help
