Hypertech programmer question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-23-2010, 03:34 PM
hunTer06's Avatar
hunTer06 hunTer06 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
Rep:60
hunTer06 is on a distinguished road
Send a message via MSN to hunTer06
Default Hypertech programmer question
I have the MAX ENERGY Hypertech for my 5.2. I am currently on 35'' tires, so I programmed the truck's speedometer for 35'' tires. When I hit the highway, it seemed like it was saying i was going much faster than I really was.
When I got home, I measured my tires. From the ground to top, they were only measuring around 33''.
Have my tires wore that much?? The air pressure is fine.
ANYWAY, I re-programmed for 33'' tires. Should I program for 33'' tires or 35'' tires?
Old 07-23-2010, 05:18 PM
What's the actual size on the side of the tire ?
Old 07-24-2010, 06:16 AM
92XJCowboy's Avatar
92XJCowboy 92XJCowboy is offline
92XJCowboy is on a distinguished road
You should set it as 33" tires on the programmer.
What kind of tire do you have? What width tire and rim? How many miles on the tires?
Tire manufacturers will sometimes over mark their tires: listed as a 35" tire but actual size could be as small as 34.6". Some also under mark their tires too.
If you have a 35x9.5" wide tire and you put it on an 8" rim your going to have a shorter tire than if you had a 35x12.5" tire on a 7" rim.
These could all be compounding reasons why your tires measure in at ~33". Its not hard when you think that every 1/4" loss on one side of the tire is a 1/2" loss on the whole tire.
--Matt
Im not an expert in anything, I just give advice based on my experiences and observations. --Matt
Old 07-24-2010, 01:05 PM
hunTer06's Avatar
Rep:60
The tire size is 35x12.50r15.
They are Maxis buckshots.
The programmer goes by 1/4'' sizes on the tire height, so I'd imagine that every little bit will throw off the speedometer.
Old 07-25-2010, 12:09 AM
92XJCowboy's Avatar
Just put in whatever you measured out as the actual size for the accurate speedo.
Old 07-25-2010, 05:38 PM
hunTer06's Avatar
Rep:60
Well just decided Im buying new tires. After I get these tires I will measure them and program whatever they measure to.
