Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
tonneaucovered.com
Old 07-23-2010, 05:52 PM
mercel lugnut mercel lugnut is offline
Vehicle: 08 dodge ram 1500 4x4 sport
Color: electric
mercel lugnut is on a distinguished road
Default 07 dodge 3500 problems
i have an 07 3500 with the 5.9 and i keep getting the engine light every so often. When i take it to autozone the code is a voltage code for injector 4-6 and right after they unplug the little reader thing the light goes off. My question is what would cause this and how do i fix it? I have a diablo programmer on it but the actual programmer was stolen from me so now it is on my truck but i can't tune it or take it off. The dealership said that this might be covered under warranty but I know if I go up there with the programmer on it they are going to tell me that it is not covered. I need some help and some advise
Old 07-23-2010, 05:54 PM
Resident Technician
Rep:1911
What's the P-code?
Old 07-24-2010, 01:41 AM
I push the skinny pedal
Rep:3308
Have you checked all the connections to the injectors as they may be loose or slightly corroded causing the intermittent voltage irregularity.
Kurtis
Old 07-24-2010, 10:18 AM
I'm not sure what you have . Your question is posted in the Cummins section , talking about a 5.9 with a predator and having a 5.7 hemi in your profile . Can you confirm what your running .
Old 07-24-2010, 01:08 PM
Color: electric
I have several trucks the one i am talking about is a 5.9 diesel. It has a diablo programmer on it and I do not know what the codes were I accidently threw the piece of paper with them on it
Old 07-24-2010, 02:06 PM
Not sure what you can do . I would say maybe try and get a used ecm and install that then take it in . Or just man up and take it in and bite the bullet . I don't think Diablosport can help you out . You may want to check with them .
Old 07-29-2010, 12:05 PM
cjames cjames is offline
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
cjames is on a distinguished road
man that harsh getting the programmer stolen id say get a new programmer and take the tune off and then get the problem fixed under warrenty
Old 09-03-2010, 10:24 PM
Diesel Geek's Avatar
Diesel Geek Diesel Geek is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:23
Diesel Geek is on a distinguished road
i have seen this before. the terminals on the bank 2 injector connectors spread apart just a bit, so every so often it will see high resistance. then pop the light on. very carefuly close the terminal on the connector just a bit. if that dont work then you will need to test the cross over harness and the engine harness for opens.
i work for a dodge dealership. if your in south carolina i could give you a hand with this.
Dodge forgot to tell every one the diesel is the SRT-6.
