Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-23-2010, 08:47 PM
ram250099 ram250099 is offline
Vehicle: 1999 Dodge Ram 2500
Color: Green
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
ram250099 is on a distinguished road
Default A/c not blowing cold
I have a 1999 dodge ram 2500 5.9 diesel and the a.c keeps blowing hot air.. i have charged the system and it will blow cold for awhile then get warm again.. i have noticed there is not water leaking out from under while i have the ac on so im not sure if somthing if blocked?
Old 07-23-2010, 09:42 PM
Rep:1845
Lots of things can cause your problem. What are the high and low side pressures? Are you sure you don't have a leak? What is the current charge level?
Old 07-24-2010, 12:03 PM
You could have several problems . We need to know what your pressures are . It's a good chance you have a decent leak .
Old 07-24-2010, 04:09 PM
Color: Green
I put the gauge on the low side that came with the bottle of refrigment and it is reading 65 psi witch is a little high
Old 07-24-2010, 04:42 PM
Yes it is . I quess you don't have a set of guages . I was hoping to get a high side pressure reading also . You may be overcharged .
Old 07-24-2010, 06:04 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Post
Sounds like you may have too much Freon in the system. It would get cold and the compressor would shut down on high pressure aka warm air.
Old 07-24-2010, 11:53 PM
Color: Green
how do you drain it out?
