Old 07-24-2010, 03:07 AM
pgorday pgorday is offline
Vehicle: 2012 Ram 1500, 5.7L Hemi, 2wd
Color: True Blue
pgorday is on a distinguished road
Default Whining ride
I have a 98 ram 1500, 318. I have a whining sound coming from under the truck. It whines up and down as speed increases and decreases. I have put the trans in nuetral and it still whines. Any ideas?
Thanks
I should add that it doesn't increase with engine rpm and i don't hear it when stationary.
Old 07-24-2010, 05:09 AM
I push the skinny pedal
Rep:3277
I would bet its either the belt or the tensioner pulley, or both.
Kurtis
Old 07-24-2010, 09:01 AM
Rep:1845
Sounds like your rear diff isn't happy. Check the fluid level and condition for starters.
Old 07-24-2010, 10:04 AM
Is the noise there when your in park and revving the motor ?
Old 07-24-2010, 08:52 PM
Color: True Blue
Thanks, i'll check the diff. And there is no noise when parked and revving engine.
Old 07-24-2010, 09:01 PM
I would have to agree , check the differential . Are you 2wd or 4x4 ? If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question or comment .
Old 07-24-2010, 09:51 PM
Definitely check your differential lube. How long has it been since it was changed?
Old 07-24-2010, 09:58 PM
Color: True Blue
I changed the fluid 10 months ago.
I am pretty new at all this so please forgive but, what kind of differential is this? There are several different ones when looking at lists. Dana 60,70, 80 and is chrysler rear ends same as dodge?
Old 08-01-2010, 10:38 PM
Color: True Blue
Okay, I've checked the diff. Fluid was ok, and i didn't see any signs of wear on the gears. Not sure if the noise I heard was a grinding noise when turning the tires. If it was, would that be the bearing?
Old 09-08-2010, 09:38 PM
motofool23 motofool23 is offline
Vehicle: 1998 Dodge Ram
motofool23 is on a distinguished road
one of your diff bearings are going bad. i had the same problem last year.
