Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Place your Ad Here!
Old 07-24-2010, 06:01 PM
Redlongbed's Avatar
Redlongbed Redlongbed is offline
Vehicle: 2002 Dodge Ram 1500
Redlongbed is on a distinguished road
Default Towing with a 360
I have a 2002 quad cab long bed 4X4 1500 with the 5.9 and a few months ago I towed a buddy's jeep from around Baltimore, Maryland to Rausch Creek offroad park in PA. It is about a 2 and a half hour drive with mainly hilly areas on 83. The ram seemed to perform well for the most part, although it was only towing around 6500 pounds, about 1800 under the recommended limit. I don't know if I would really want to push the tow weight rating to the max though because it didn't really struggle but it didn't seem to like it too much. I haven't towed much and maybe that is why I feel this way. Any insight from anyone who tows with a 5.9? Also, when I was just about to rausch there is a long, very hilly mountain road and the temperature gauge began to climb as I drove, however when I turned the O/D off it dropped down is this because the tranny was getting hot? If so, when should I use the O/D button to avoid this? Also my truck seems to burn oil when I tow. I was a quart low upon reaching Rausch and I could smell it burning when I got out. This has happened when I was hauling a bunch of wood before also. Any tips, comments, stories would be much appreciated!
Old 07-24-2010, 08:23 PM
The oil use may be from a defective intake manifold belly pan gasket . Not uncommon on these type of intake manifolds . Yes when I flat tow as long as I'm not laboring the truck I'll use O/D . But when it comes to the hills , I find it better to disable it .
Old 07-24-2010, 08:45 PM
I agree with what Tom ^^^^ said. Check that intake manifold belly pan gasket and for any other oil leaks you might have.
I use O/D when on a fairly flat surface but as soon as I hit some grades, I get out of it even though I know the engine will be running at a higher RPM. I'm more worried about overheating the trans by slipping it with a load in O/D
Old 07-25-2010, 12:36 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Yep o/d off for the non flat stuff
Old 07-30-2010, 02:35 PM
Redlongbed's Avatar
Thanks guys I'll have to check it out.
Old 07-31-2010, 01:09 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
O/D off whenever your towing anything, hills or not. By leaving it on, you can overheat the tranny and kill the pump, ending your trans' life.
I'd rather turn the overdrive off and pay for a little more fuel than risk the trans being messed up.
But...I had a Dodge tech tell me that these trannies are unbreakable, unless you leave the overdrive on while towing.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 07-31-2010, 02:19 PM
I'd also look into a trans oil cooler for your truck.
