Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 07-24-2010, 07:03 PM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
Default Hell Bent leveling kit's????
Hi, My first Post
Has anyone bought these kits and have any comments or suggestions??? http://hellbentsteel.com/ They seem like a descent kit!!! If a guy does level the truck, Do you need a wheel alignment, does 2-2.5 inches really affect it.???
Thanks ,
CapperRAM
Old 07-24-2010, 11:01 PM
Rep:1625
A couple members on here have that kit, I don't so I can't give you a review on that particular kit. But I do have the Daystar leveling kit and you definitely need an alignment afterward.
Old 07-24-2010, 11:29 PM
I too have the Daystar kit and yes it effects toe in . It will need an alignment .
Old 07-26-2010, 02:12 AM
0007 0007 is offline
Vehicle: 2008 ram
Color: Bright blue
0007 is on a distinguished road
Don't want to hijack this but how does the leveling kit affect handling?
Old 08-29-2010, 07:08 PM
BukSlyr BukSlyr is offline
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
BukSlyr is on a distinguished road
I have them on my truck. They havent been a problem. You might want to read up on the death wobble issue first before you install them. I have it BAD!!! Just popped up and signs are pointing towards the leveling kit. I got it realigned and all was good until last week.
Old 10-15-2010, 12:53 AM
Crawler Hauler Crawler Hauler is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Crawler Hauler is on a distinguished road
My only concern is the steel on steel that you will get from HBS.
Daystar is popular because theirs are encased in urethane. From their website:
•No Metal-On-Metal Contact - Daystar uses Polyurethane material in its Leveling Kits for a reason: It's an insulator. It absorbs the Noise, Vibration, and Harmonics (NVH) that come from the suspension and avoids transmitting them to the passenger compartment. All competitors use steel or aluminum in their Leveling Kits. If you were to take apart any factory suspension, you are going to find rubber, polyurethane, and often both in a typical suspension. These pieces are there for a reason; they absorb the NVH. Sure, steel makes a great hammer, but would you want to ride on it?
Good points. Note that Daystar is not the only company making them this way.
Old 10-15-2010, 01:00 AM
I doubt that the death wobble is coming from the leveling kit, though it might be making it worse.
I would bet that your death wobble is coming from a worn tie rod end. That's if it is death wobble and not bump steer. There is a difference. Google it and search YouTube for videos of each.
Once you know that you have death wobble and not bump steer, do a dry steer test. Again, go to Google and YouTube to learn how to do this.
