Old 07-25-2010, 02:28 PM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
Exclamation Need some wheel info in a hurry!
I have the stock 20 inch rims(2002-2005?) on my truck and my friend is wanting to buy them. He has the body style before mine. His truck is like a 2000 or so. Well we put the rims on his truck one day and the lugnuts didn't go on all the way? What do we have to do to make them fit? Did we just put the rim on wrong or does he need extended stems? Anyone who knows your info will help alot!
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 07-25-2010, 02:47 PM
Hard to tell from the description but I think I can help. Got a few questions for ya:
1. Did the wheel seat all the way back to the hub?
2. If so, how much lug was showing past the wheel hub?
3. If there was sufficient lug length, did you use your lugnuts or his? His lugs may have a different thread pitch.
Old 07-25-2010, 02:49 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
id say if the lug nuts didnt go on all the way then they are bottoming out on the stud. sounds like you may need different lug nuts. the wheels should work just fine on the truck.
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 07-25-2010, 02:52 PM
Rep:98
You know man, I have no clue. We put the rim on right, but he insists on saying it "didnt fit." I don't remember which lugs we used. All I remember is I tightened them up and he drove down the road with no problems. I will try again today and use both sets of lugs and find the exact problem. I've been researching and there is supposed to be no problem. Just a simple swap from the old rim to the 20 and thats it.
Old 07-25-2010, 03:03 PM
Yeah, they should fit. Just not sure what he means by saying it "didn't fit". If the lug nuts go all the way down and you can snug the wheel all the way up to the hub, then there shouldn't be a problem.
My only other thought was which lug nuts were used and if they are an open style lug nut (lug threaded end comes through the nut) or acorn style which covers the lug end when installed.
Old 07-25-2010, 03:09 PM
Color: Cool Vanilla
Rep:63
well if he drove down the road with no problem then i dont see a problem.
Old 07-25-2010, 03:11 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
I agree with maddog on the lug style being your problem, or you could try shorter studs. Ive seen plenty of gen2's with gen3 wheels
Old 07-25-2010, 03:13 PM
Rep:98
Yeah we will have to try them both. His truck has the open end lugs and I have the acorn lugs. I see the 2nd gens with 20s all the times. I dont know why he wont realize this lol
Old 07-25-2010, 03:38 PM
There is one other thing to look at. Check the shoulder area (where the nut comes in contact with the wheel hub) to see if they are the same style as well.
Your acorn style nuts may not have been long enough and the lug bottomed out.
Old 07-25-2010, 10:17 PM
Rep:98
We swapped em' out and they fit. What had happened was the last time he was looking at one his lugnuts that was longer than the others(he has open ended lugs) and he thought that his stud wasnt poking through the rim enough. So today I made sure that he knew it all was the same. Come to find out you don't need any modification at all to swap Gen3 rims to Gen2s. You will have to keep your Gen2 lugs though because the studs on the Gen2s are smaller than the Gen3s
dodge ram stems, stock 20s on older truck, wheel problems
