Home Made Catch Can Idea - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 07-25-2010, 05:08 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default Home Made Catch Can Idea
Ok, I've been looking at the catch cans available and don't like the price tag. So, I have an idea and wonder if it would work.
Use threaded PVC pipe and a threaded PVC cap, plus a glue on PVC cap.
Drill 2 holes and thread them for input and out put nipples for the hoses.
Cut the pipe to about 2" in length and glue a cap on one end.
Insert nipples into the screw on cap, cut the PCV hose or replace as needed for length.
Screw the PVC pipe with glued on cap to the lid with the hoses connected.
I was thinking of using 1.5" pipe, is this large enough?
As I understand how the system works is the oil is heavier than the air and will just fall to the bottom as the air from the PCV passes through the container, correct? It is a low pressure setup, correct?
Just need to figure out where to mount it, which shouldn't be to hard.
Brian:
Old 07-25-2010, 07:20 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I am a visual person, so you better just make it up. I am looking at making my own too, but was going to use the thing from an air compressor.
Old 07-25-2010, 07:26 PM
Color: RootBeer
Rep:1287
Actually using the moisture trap from a compressor is an even better idea because it's clear so you can see when it needs to be emptied plus they usually have a drain on them if there's space under it to drain it.
Brian:
Old 07-25-2010, 08:25 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I've seen threads on the air compressor seperator setups. I think I googled "DIY oil catchcan" or something to that effect.
Old 07-25-2010, 08:46 PM
Color: RootBeer
Rep:1287
Here's a link to the DIY catch can using a compressor filter. Seems pretty simple. I wonder if it really needs to be mounted rather than just hanging on the line. Guess I need to look under the hood when the temp drops below 100 outside.
http://www.crxmpg.com/diy-pcv-catch-can/
Brian:
Old 07-25-2010, 11:14 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
they like 60 bucks
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 08-02-2010, 03:44 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I would mount it since the weight will increase as it fills up and the hoses will loose stiffness when hot.
Ditto on the use of the air line dryer idea. The clear housing will aid in inspection and it's rated to a much higher pressure than you'll be able to get with the PVC option. All the o-rings/gaskets are included as well.
Old 08-03-2010, 12:29 AM
nitro1965's Avatar
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
i also would mount it also
