Old 07-29-2010, 02:56 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default How to Do a Lift Properly
Ok, I've looked through the How To's and didn't see one on this subject, except the one about the 3" body lift. This is for those higher lifts.
I'm no expert on the subject and I'm hoping someone with a lot more knowledge will step in and fill in what I left off.
I have a mechanical background and an engineering background, so I tend to look at things from that perspective.
I've seen a lot of posts about people wanting to lift their trucks for various reasons; big tires, mudding, off-roading, looks (this one usually can be accomplished with the 3" body lift), etc.
Lifting a truck can seem like a simple thing to do. Buy the kit, lift it up, and put the kit in and you're done.
Doing it right is not quite that simple or easy. There is a lot of knowledge and design that needs to be taken into consideration.
Here's some things you need to consider:
1. Will the angle on the u-joints be to steep?
2. Will the drive shafts be long enough after the lift is done?
3. Will the angle on rod ends and the rest of the steering mechanism be to steep?
4. Will the hoses connected to the steering box be stretched to far?
5. Will the steering shaft reach?
6. Do the shocks and springs need to be changed?
7. What will happen when you're off-roading and you end up with one wheel extended fully down, will it rip out everything connected to it?
These are just a few things that come to mind. Not taking them into account can be a costly venture in repairs.
Just because you take your truck to an "off-road" shop to have the work done, don't count on them knowing how to do it correctly. Take a look at some of their work. A sure sign they don't know what they are doing is on a 6" lift the axles are still sitting in the stock position rather than turned up facing the drive shaft (the to steep of an angle on the u-joints comment above).
As I said, I'm sure there are many more things to consider, these are just what comes to mind for me at this time.
Brian:
Old 07-29-2010, 03:27 AM
Rep:4072
Nice writeup. I haven't done a lift myself, but some great suggestions here!
Old 07-29-2010, 08:04 AM
iRESQu iRESQu is offline
Rep:2217
Anyone have the email address for the place that messed up my lift that we could send this "non professional" install directions to? An improper install, thus far, has left my without my truck for a week. THANK YOU ROOT BEER AND GREAT JOB!
Old 07-29-2010, 10:39 AM
Rep:1625
Nice info RootBeer
Old 07-29-2010, 10:56 AM
I push the skinny pedal
Rep:3277
I always thought it was with your legs, keeping your back straight... but maybe I've been wrong all these years That's great info RootBeer, I can't think of anything else to add off-hand.
Kurtis
Old 07-29-2010, 12:58 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
I can answer all your big lift questions or concerns root beer. So PM me or post on this thread if you need them answered.
SUL73NAZ
Old 07-29-2010, 01:41 PM
Color: RootBeer
Rep:1287
I don't have any questions because its not something I am planning to do.
I just thought we needed an in depth thread on how to do it properly.
So, please put in what you know.
Brian:
Old 07-29-2010, 01:50 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
I have alot of info. Two categories come to mind. Trucks with solid axle front ends and ones with ifs (independent front suspension). In either case the higher you go the more things will need to be modified. For instance I went from 9" of front lift with a stock steering set up on 37's. The jump to 14" of lift an forties brought on a whole new dynamic of things that needed to be modified.
SUL73NAZ
