Old 08-09-2010, 12:00 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
Default steering gear on my '97 Ram 1500 4X4
Input shaft seal is leaking..... I see most repair kits are $6-7 bucks, and a complete seal kit to do the whole box is about $17.
IF I have to take the box out just to do the input seal, I will do the whole box. If I can do it 'on the truck'... I will just do the input seal.
Is it possible to do it 'on the truck'?
Thanks!
Bob
Old 08-09-2010, 12:33 PM
Rep:1877
For the little effort it takes to remove the box, I'd take it off. It's just 3 mounting bolts, p/s hoses, the input shaft and pitman arm.
Old 08-09-2010, 01:51 PM
umrminer98 umrminer98 is offline
Vehicle: 1998 Ram 1500 4X4
Trim Level: Carpenter Special
umrminer98 is on a distinguished road
Everything comes off the truck easy, but when I took the pitman arm off the box it had to go to a machine shop and be pressed off and it still took them 45 minutes to get it off. So just be warned that could be a problem if you want to get that off for the bottom seal.
