Old 07-29-2010, 02:10 PM
05Blackout 05Blackout is offline
Vehicle: 2005 Dodge Ram 1500 SLT
05Blackout is on a distinguished road
Exclamation 2005 engine problems and questions
What's going on.
I've got a few problems, a couple of days ago I put seafoam in my gas tank. I stalled out from taking the truck out off drive to park, then to reverse. The next two days I had the check engine on, but it turned off the third day.
I had codes checked on the truck and it came up with engine code 302 (miss fire).
The other day I removed the crankcase cap and added more seafoam. The engine light turned back on, I'm assuming it's the same problem.
Also, it looks like I have gunk on the underside of the crankcase cap and also in the groves which the cap screws into.
Any advice?? Anyone have miss firing problems?
Thanks
Old 07-29-2010, 08:23 PM
Just went outside to give it a test run, The truck does not rev past ~4.2k RPM. Im not sure where the redline is either.
Old 07-30-2010, 08:20 PM
RamCountry's Avatar
RamCountry RamCountry is offline
Vehicle: 2006 Dodge Ram
Trim Level: Reg. Cab Laramie 4x4
Color: Atlantic Blue Pearlcoat
Rep:64
RamCountry will become famous soon enough
i wouldnt keep putting the seafoam in you proabably need to change the spark plugs cause its about time too and the truck will only rev to 4k rpm with no load on it the computer limits it in park and neutral just change the spark plugs which are cheap and go from there
Old 08-01-2010, 03:38 PM
Okay, Thanks for the info!
Old 08-02-2010, 09:23 PM
JR23 JR23 is offline
Vehicle: 2003 Quad Cab 2wd 5-speed
Color: Maroon
JR23 is on a distinguished road
Has anyone tried Gunk engine flush? Is Seafoam a good preventative measure for high mileage applications? I have listen to people swear by marvel's mystery oil also. Never used any of this stuff, but always interested in new ways of maintaining.
Old 08-02-2010, 09:37 PM
Rep:1885
As in crankcase flushing? Bad idea if that's what you mean.
Old 08-02-2010, 10:16 PM
RamCountry's Avatar
Rep:64
yea really bad idea, cleans things that shouldnt be cleaned
