Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 07-29-2010, 06:14 PM
r1buden r1buden is offline
Vehicle: 2004 Dodge Ram
Trim Level: 2500 Off-Road
Color: Charcoal Grey
r1buden is on a distinguished road
Default 2004 Dodge Ram 2500 brake controller connector
under the dash of of my 2004 dodge 2500 I have the blue connector to plug in my brake controller...I am having some issues and I am wanting to make sure that it is wired correctly.
the connector under the dash has White/Red, Green , White, and Black
which is Ground, Power, Trailer Brakes....and what is the fourth
I have no blown fuses...check 1 and 19 and no power LED on the controller..
I have a tekonsha envoy with the tekonsha adapter the wires are Black,Blue,Red, and White.I have the tekonsha wiring harness that is also black,Blue,Red, and white...and I have it wired Black-black,White-white,Red-red,Blue-Blue. if I jump the blue wire straight to ground...I get the green light and when I use the slide it turns to red. but no power on red when I step on the brake...any ideas....
is something wired backwards in my connection to the under dash connect...
thanks
Old 07-29-2010, 08:50 PM
I have done some more troubleshooting. Everything is wired correctly to the under dash connection. but when I step on the brakes the red wire should become energized, it does not...so I am guessing there is a short somewhere or the switch on the brake is bad...however all lights work correctly. any one have any ideas?
Old 06-16-2011, 03:23 PM
kujo70 kujo70 is offline
Vehicle: 2008 Dodge Ram
Trim Level: ?
kujo70 is on a distinguished road
I Hello, i own a 2008 Dodge ram 1500, I connedted a break control to the blue connector i found near or behing the hand brake pedal. does the wiring of the blue connector goes all the way to the back of the truck.
Thanks
Old 06-24-2011, 06:46 AM
NORFLA71's Avatar
NORFLA71 NORFLA71 is offline
Vehicle: 2008 Ram 3500
NORFLA71 is on a distinguished road
You are on the right track. I also had an 04 HD and ran into the same issue. A local U-Haul installed my Prodigy and had to troubleshoot. It turns out that if you don't have the factory tow package one of the wires will not be connected through the blue connector and you must run a separate wire back to the pin; it's been 6 years since I had that truck and do not remember which one it is (the green wire, I believe). If you have the factory package it may still be the same issue. It took the store about an hour to find the problem.
Stock, for now...
