need help- on exhaust were to buy x 2 3/4" pipeing - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > Exhaust
Old 07-29-2010, 06:20 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default need help- on exhaust were to buy x 2 3/4" pipeing
2010 ram rt i have american racing headers come down to 2 7/8" i want to and and x pipe that will fit this and run the piping out as dull 2 7/8" or at least 2 3/4". i dont want to do 3" its to big for my motor or the power iam putting out. the 6.1 hemi srt in stock form is putting out 425hp and it comes stock with 2 3/4" exhaust piping. i putting out about 450hp with my mods i plan to do the e fan and bottom pully so i should pick up more hp and free up more. so what size exhaust should i run? should i just cut the headers at the y and weld on a 3 1/2" pipe stright out with muffler, orfrom the headers an x pipe that is 2 1/2", 2 3/4" 3" with the like in pipe size going out. on my dyno when my hp hitts 350hp its stright flat. its at its max flow rate. when i compare my motor with same mods with the challanger rt they are putting down 20 30hp more. on there dynos it peaks than drops at max rpm, mine is stone wall flat. so the set up i have with the headers flowing into a y pipe in to a 3" pipe then in to a single inlet 3" muffler and out of the muffler dull
2 1/4" pipes is not flowing enough. i think its the 3" middle section. what has a larger surface area? 3" pipe or 2-2 1/4" pipe. please help!
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 08-05-2010, 11:10 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
i think they are cammed differently so its hard to compare apples to apples... dynos will be diffrent because of the heavier wheel setup the truck has and the bigger drive train loss too...
the 2.25 after the muffler is good for tq but goin to a 2.5 may get you more hp..
Old 08-05-2010, 11:16 AM
chefred112's Avatar
Rep:656
nevermind, you already re-did your setup..looks good..
Old 08-05-2010, 07:18 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default thanks
i can always count on you. thanks bro
Old 08-05-2010, 07:55 PM
chefred112's Avatar
Rep:656
..i wanna see your truck scream down the track, don't know anyone else with a 4th gener willing to mod up...keep up the good work!
