Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 07-29-2010, 09:16 PM
05Blackout 05Blackout is offline
Vehicle: 2005 Dodge Ram 1500 SLT
05Blackout is on a distinguished road
Default 2005 Electrical Problems!
Whats going on!
So far, Ive noticed that when I use my left turn signal, sometimes it blinks right. In example. The other day it blinked left 3 times, right 2 times, then left 1 time before I finished my turn. Really spooky?!? I think so hehe. Sometimes it flashes both ways when I use the left turn signal.
When im using my headlights, if I don't turn them off before I shut the truck off they stay on. Now only the headlights stay on, everything else shuts off.. This is also kinda freaky, to me atleast :P. This has only happend twice so far.
I have only had the truck 10 days, I haven't exactly used it much.
Has anyone experinced these problems before?
I will update if these problems continue as im sure they will.
Thanks!!
Old 07-29-2010, 09:25 PM
Turn signal still spooky. I relized that the headlights infact do turn off.. Just takes a minute or so haaha
Old 06-06-2013, 09:29 PM
mudrunnr mudrunnr is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: TRX 4
mudrunnr is on a distinguished road
Welcome to the forum. I am not sure if this will help but it is real similar to an issue I had. I also noticed my headlights would stay off if I turned the truck off first and then the lights. I found the 4 prong trailer connector had corroded inside the protective dust cap. It is worth checking it out and if it is bad you just snip it off and then splice in a new 4 prong connector. Let us all know if this helps or if you need further assistance. Best of luck.
Old 06-06-2013, 09:40 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
You would be correct. It's a safety feature and it's supposed to do that. As far as the turn signal light going back and forth, that sounds like your indicator switch is about ready to call it a day. I'd look in to getting a new one and getting it replaced.
Old 06-16-2013, 09:23 PM
BigxRam BigxRam is offline
Vehicle: 2007 Dodge Ram
Color: Blue
Rep:23
BigxRam is on a distinguished road
Check Ramtech's post "multifunction switch" above. Sounds a little light your blinker issue.
