Old 07-30-2010, 11:48 AM
inkredible
Default 4x4 vs 4x2
2010 hemi has 390 hp so if your truck is 4x4 so you should be seeing all of that 390 whereas if you have a 4x2 hemi would you not see all of it?
or am i thinking to much like a sports car and 4x4 doesnt work that way at all
Old 07-30-2010, 11:58 AM
Rep:1885
You have 390 HP no matter what because that's measured at the flywheel.
Old 07-31-2010, 02:10 AM
CustomShirts's Avatar
CustomShirts CustomShirts is offline
Color: White 2-tone
Rep:172
CustomShirts has a spectacular aura aboutCustomShirts has a spectacular aura about
That is correct... what would be measured at the wheels has a lot to do with a lot of different things.
Tim
Old 07-31-2010, 03:59 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Actually, a 4X4 will put slightly less power down than a 2wd because the front differential and transfer case will eat a few ponies. In reality a 4x4 , especially in 4WD Low will pull the guts out of a 2wd.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 07-31-2010, 04:01 PM
Rep:1885
At the wheels, yeah, but the flywheel HP ratings are the same regardless.
Old 07-31-2010, 04:18 PM
Driveline losses are driveline losses. Probably more loss in 4WD than in 2WD (more mass to power and rotate) and besides, who needs 390 HP in the snow?
Old 07-31-2010, 04:20 PM
Rep:1885
Ever seen snow drags?
Old 07-31-2010, 04:24 PM
Yup...but traction is a problem for anyone in the snow. Same thing on mud. I stand by what I said...who needs 390 HP in the snow? You need traction!!!
Old 07-31-2010, 06:14 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
its good to have extra ponies in the mud...when you get in the real thick shit you need them to keep tires rotating and cleanign out the mud to keep traction...that happened to my buddy...so bogged down truck didt have enough power to turn tires
DODGE the father RAM the daughter!
Old 08-01-2010, 11:08 AM
inkredible
So theoretically if someone wants to challenge me on the highway in their ram both stock but he is 4x2 and I'm 4x4 driving skill the same (its a straight line anyway -_-) he has an advantage?
