Old 07-30-2010, 02:40 PM
Redlongbed's Avatar
Redlongbed Redlongbed is offline
Vehicle: 2002 Dodge Ram 1500
Redlongbed is on a distinguished road
Default Leveling kit and effect on steering
I have a 2002 dodge ram 1500 4X4 quad cab and I just installed a readylift leveling kit on the truck and put some new tires on. The 02 rams use torsion key leveling kits. I took the truck to a local shop to have it aligned as readylift recommends. The shop owner called and said that the leveling kit affects the rack and pinion steering because it changes the angle and is no longer parallel with the frame. He said this could cause irregular tire wear and alter the handling of the truck. I have not heard anything about this until now. Is this something I should be concerned about and if so is there a way to make the rack and pinion parallel again, maybe with spacers? Any help is appreciated. Thanks!
Old 07-30-2010, 03:42 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
call around i jut had my 7 inch cst lift put on and the alignment shop said i needed a camber kit.
so my alignment cost me 308 bucks with a discount.
i called cst they said out of the thousands of lists they installed 1\3 of them being the 7 inch they said they never needed or heard about needing a camber kit. then the shop that installed it said they would of put it in for free if i would of came back then another tire shop said it should of only been 150 for everything.
but i found all ths out the day after getting the camber kit and losing 300 bucks! so before they do anything like that call around try calling readylift and some local shops
Old 07-30-2010, 08:10 PM
carrayz's Avatar
carrayz carrayz is offline
Vehicle: 1999 dodge ram 1500 ext cab sb
Trim Level: laramie slt
Color: silver
Rep:21
carrayz is on a distinguished road
i was thinking about a kit,this helps
Old 07-30-2010, 09:13 PM
RamCountry's Avatar
RamCountry RamCountry is offline
Vehicle: 2006 Dodge Ram
Trim Level: Reg. Cab Laramie 4x4
Color: Atlantic Blue Pearlcoat
Rep:64
RamCountry will become famous soon enough
i wouldnt worry about it a leveling kit isnt going to change the angle of the rack and pinion enought to affect steering now if you have a huge lift then i would get tie rod end spacers but for your situation i wouldnt worry
Old 08-01-2010, 09:58 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
Thats BS! if they aligned it right there will be nooo problems at all
Old 08-01-2010, 10:01 PM
Rep:1909
A leveling kit changes the caster, camber and toe angles significantly and can result in a poor handling truck.
Old 08-01-2010, 10:18 PM
mattg1500's Avatar
Rep:22
if i could ask, how does it change caster? I know it changs camber and toe but the wheel isnt being moved back or forward to change where the knuckle sits. Is caster adjustable on a 1500?
Old 08-02-2010, 05:49 PM
RamCountry's Avatar
Rep:64
when it changes the camber and toe it will knock caster out as a result and im not sure caster is adjustable maybe with aftermarket eccentrics or cambolts
Old 08-02-2010, 05:54 PM
Rep:1909
Caster and camber are adjusted via slots in the upper control arm mounts.
Old 08-02-2010, 06:34 PM
RamCountry's Avatar
Rep:64
i figured just wasnt sure thanks for clearing that up!
