Old 09-09-2010, 04:15 PM
BigJim1500's Avatar
BigJim1500 BigJim1500 is offline
Color: Deep Water Blue Pearlcoat
Rep:59
BigJim1500 will become famous soon enough
Originally Posted by brettwal View Post
Remember the Motto:
"It's only illegal, if you get caught!"
(It will not void the warranty, it does not modify any factory part. Remove it and all functionality will go back to stock)
It also has a feature to disable it. No one will know it's installed untill you enable it again.
[B][COLOR="Blue"][U]BigJim1500[/U]:[/COLOR][/B] 2010 1500 Laramie CC, BLUE, Mopar Tonneau, Short Black Antenna, Lockpick, Pinnacle 50% Tint (all around), K&N Drop-in, Cat-Back in the Spring
Old 09-12-2010, 07:56 PM
seanhofmann's Avatar
seanhofmann seanhofmann is offline
Vehicle: 2010 Dodge ram 1500
Color: White monotone
Rep:25
seanhofmann is on a distinguished road
thanks for the input on the wire to the camera, I read the instructions and thought no thanks.
Old 09-13-2010, 12:03 AM
rlandon's Avatar
rlandon rlandon is offline
Vehicle: 2010 Dodge Ram Crew Cab 2WD
rlandon is on a distinguished road
I had one on my Nitro and did the following mod. Buy a cheap $40 digital TV tuner and plug that to the aux of the Lockpick and you then have local TV!
Previous Rams: 1954 C1-B6 Rodded, 1976 D100, 1994 RC, 1998 Supercharged EC, 2003 QC R/T Custom.
Old 09-13-2010, 12:59 PM
zevrosenthal zevrosenthal is offline
zevrosenthal is on a distinguished road
If you are using both a front/baby cam and rear camera, you will have to run the wire from the lockpick to your rear camera per the instructions - at least with 2010 RAM 3500. I discovered this when i did my recent install. It seems the rear camera is always supplied power when the vehicle is on (from the existing dodge harness). Thus, when I put on the front camera, the rear camera was also still on causing both signals to mix and a create a useless image on the screen. I had to run the wire and connect it to the rear camera power to let the lockpick turn off the rear camera when you turn on the front camera. The hardest part is snaking the wire from the dash back to the tailgate. When I opened the tailgate, it was very easy to see the red power lead coming out of the tailgate camera and cut it away from the original harness and hook it to the power lead from the lockpick.
Old 09-13-2010, 04:03 PM
BigJim1500's Avatar
Rep:59
Wow, Thanks for convincing me to not install a front camera. Some mods aren't worth the effort. (Can that be?)
Old 09-13-2010, 04:16 PM
Jim Ram's Avatar
Jim Ram Jim Ram is offline
Vehicle: 2010 Ram 1500
Jim Ram is on a distinguished road
Thanks for that writeup, now I know I gotta have my friend who works at Best Buy (doing installs) to do it for me! Also, do you have a pic of where you installed the front camera?
2010 Ram 1500 Navigation
2007 Accord EX V6 Navigation
Old 09-14-2010, 07:56 PM
for that I was lazy. The front cam you can buy with the lockpick (from coastal tech) has 2 screw holes that match the holes in the license plate so i just mounted it on the top of the license plate. Works fine - 2 minute install.
Old 03-14-2011, 12:33 AM
Leviathan Leviathan is offline
Vehicle: 2010 Ram
Color: Brillant Black/Silver
Leviathan is on a distinguished road
Thanks guys. I am installing all of this on Tuesday. This is some great info. I got excited there for a second thinking that I would not need to run the power to the rear camera, but alas, the front camera is worth it to me.
5% Tint, MyGig Lockpick, Front Camera, BedRug, Shorty Antenna, A.R.E. CX Truck Cap.
