Old 07-31-2010, 09:30 PM
stmabe's Avatar
stmabe stmabe is offline
Vehicle: 2001 Dodge Ram Quad Cab
Trim Level: SLT Laramie
Color: Dk. Garnet Red Pearl Coat
stmabe is on a distinguished road
Default Transmission help needed (again)
Ok I replaced the pressure governor, pressure sensor, and control solenoid today got everything together and now another issue.
When you first put on gear either reverse or drive it will move ok then after a little bit won't move at all.
I was so aggravated that I haven't messed with it after that.
Anyone got any suggestions.
Thanks
Old 08-01-2010, 12:09 PM
Rep:1890
Sounds like something is binding up or leaking internally. Probably time for a rebuild.
Old 08-01-2010, 02:11 PM
stmabe's Avatar
Ok after I calmed down and slept on it I went back and check it was low on fluid. I had underestimated how much fluid had I had lost. Added 2 more quarts everything works fine now. Drove it back to the house about 120 miles shifted like a new one.
Thanks to everyone for the help
