Old 07-31-2010, 11:00 PM
Kamishoner Kamishoner is offline
Vehicle: 2007 Ram
Trim Level: Quad Cab Big Horn
Color: Penn State Blue
Kamishoner is on a distinguished road
Default General A/C question
I have and 07, 4.7L V8 and I live in AZ. It get's pretty hot but compared to Iraq and Saudi, I don't need to turn on the A/C. Well I driving and the Temp read 110 and my dog was just about die'ing in the heat so I decided to trun on the A/C. Well the A/C is coming out like as if the A/C is turned on a cool day. It's not blowing hot air but yet it's not cooling anything down at all. Ok maybe it bring it down a few degrees. But any help would be great.
Old 07-31-2010, 11:06 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
im not an AC expert...but i know all vehicles run different temps of AC in hot weather...I believe the AC temp must be 20-30 degrees less inside the vehicle than what the temp is outside...so, if it is around that number, your AC should be running properly...
Old 07-31-2010, 11:41 PM
Vehicle: 2007 Ram
No it's no where near 20-30 degree's cooler inside. It's at most 10 degrees and that's me being generous.
Old 08-01-2010, 01:29 PM
RamTech RamTech is online now
Rep:1877
Have you checked the R-134 level and line pressures yet?
Old 08-01-2010, 11:13 PM
Vehicle: 2007 Ram
I have no idea what an R-134 level is, and how would i go about checking that and the line pressures?
Old 08-01-2010, 11:22 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
You need to put a set of AC guages on and have a look at the pressures with the AC compressor turning. Should see around 30psi on the low side and around 150psi on the high side. However if you are unsure of what you are doing you need to take it to an A/C shop and have them check things out for you. IMHO
