Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 07-31-2010, 10:09 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default Missing Bolts in Wheel Well
Just curious, shouldn't there be a bolt in each hole holding the fender to the inner fender/wheel well?
My truck is missing about half of them.
Brian:
Old 07-31-2010, 10:17 PM
iRESQu iRESQu is offline
Rep:2217
I am too.....I think they are designed that way. When I went to put on my fender flares, I noticed that, but the hardware they sent to adhere the fenders with, was the same amount present.....anotherwords, there wasn't hardware for every hole.
Old 08-01-2010, 07:36 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
I was able to use all the hardware that came with my fender flares and they plugged up all the holes when I did the install.
Old 08-01-2010, 11:32 AM
Resident Technician
Rep:1915
All the holes are only used when fender flares are installed.
Old 08-01-2010, 12:10 PM
Rep:2217
I stand corrected with my wrong info......I went and looked at my truck and Randy is correct, my hardware did fill every hole. Sorry all....next time I will go look before I answer.
Old 08-01-2010, 12:20 PM
Resident Technician
Rep:1915
You goober!
Old 08-01-2010, 12:22 PM
Rep:2217
Sorry Randy. I should've gotten off my butt and went and looked BEFORE I answered. I was trying to recall off the top of my head. I thought I had run short of hardware...but I am a "goober".....
Old 08-01-2010, 12:31 PM
The holes not already filled with bolts to the fender were used to attach the chrome trim that was on mine when I bought it.
I removed that and expect to use the holes when I install flares.
Old 08-01-2010, 11:48 PM
Color: RootBeer
Rep:1287
Does that mean the nut clips should be in place on the inner fender?
Brian:
Old 08-01-2010, 11:56 PM
I doubt the nut clips are there. Most flare kits include a set of those for installation.
