Old 08-01-2010, 03:33 AM
984wdram 984wdram is offline
Vehicle: 1998 dodge ram
Color: deep amythest and silver mist
984wdram is on a distinguished road
Default o2 sensor high voltage
check engine light came on when i cranked my truck up the other day. took it to get it tested and the girl that did it said it was a bank 2 02 sensor high voltage code. went inside and looked it up and it said intake manifold o2 sensor. she cleared it and now its on again. could it just be unplugged? is this the right sensor?
Old 08-01-2010, 01:16 PM
Rep:1877
Um....there's no such thing as an intake manifold O2 sensor. What was the actual P-code number?
Old 08-01-2010, 06:30 PM
p0138. O2 Sensor Circuit High Voltage (Bank1, Sensor2)
Old 08-01-2010, 06:47 PM
Rep:1877
That would indicate a problem with the left bank downstream sensor, specifically with the heater circuit. It's been my experience that the sensor itself is normally at fault when heater codes are thrown.
Old 08-02-2010, 06:28 AM
which would be located where?
Old 08-02-2010, 06:49 AM
Rep:4072
Your downstream O2 sensors are located after your catalytic converter, but I'm sure Randy would have a diagram if need be.
Old 08-02-2010, 08:34 AM
Rep:1877
Left bank of the engine after the converter.
Old 08-03-2010, 05:52 AM
gotcha. will this effect my fuel milage or performance any?
Old 08-03-2010, 09:01 AM
Rep:1877
It can have a negative effect on both.
Old 08-04-2010, 08:49 AM
well my check engine light was off all day today. i crawled under it the other day and tinkered with it a lil bit, musta fixed it.
