Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-01-2010, 04:03 AM
coredawg coredawg is offline
Vehicle: 2010
Trim Level: SLT Big Horn
Rep:20
coredawg is on a distinguished road
Default Steering binding
I have an '05 Hemi SLT with an odd problem in the steering. At slow speeds or stopped, i have a slight binding or slight lack of power steering when I first start turning to the left. Happens when I am turning into my driveway or making slow speed turns. It only happens to the left, not the right. I am not sure if it is something in the rack or in the power steering pump.
I could change both of them, but would rather see if anyone else has had a similar problem so I can change only the problem part. Any help would be appreciated.
Thanks All
Old 08-01-2010, 12:36 PM
Rep:1845
If it wwere a pump issue, it should happen in both directions. I'd look for binding in the gear, rod ends or ball joints.
Old 11-18-2010, 07:28 AM
brownlostsoul brownlostsoul is offline
Vehicle: 2006 Dodge Ram 2500 MC 4x4
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
brownlostsoul is on a distinguished road
My 06 2500 MC 4x4 Cummins has the same steering issue. Did you figure out the problem
Old 11-18-2010, 07:38 AM
Rep:1845
Your steering setup is different than the 1500. Start by making sure your steering stabilizer isn't damaged. Take one end of it loose and see if the binding disappears. Also check the clamps on the drag link adjuster and make sure they aren't contacting the frame when you turn left.
Old 05-13-2012, 11:02 PM
Kazi Kazi is offline
Vehicle: 2007.5 Ram 2500
Color: Gold
Kazi is on a distinguished road
Not sure if anyone's still tracking this thread but I have the same problem. I've replaced the pump, booster, gear box, pressure lines, tie rods, and drag link assembly. turns smooth as can be with the front end off the ground or on the ground in dirt or wet concrete. I'm running amsoil atf... Please help if anyone's figured this out.
