Old 08-01-2010, 11:13 AM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
Default '97 5.9 misfire
My 97 Ram 1500 with the 5.9 and automatic started missing yesterday.
I was heading to town, about 30 mile trip, at my usual 60-70 mph... and noticed at first it was 'bucking' a little. When I came up to the first stop sign, it sounded fine. But when I accelerated away from I could hear the miss. When I 'pushed it' to maintain 60+ mph, it does it. When I push the OD switch off, and the motor doesn't have to torque as hard, it seemed better. But as soon as I roll back onto the gas, starts missing again. About 10 miles from town, finally popped a check engine code. I shut it down, and restarted it several times. It starts right off, just like always. At first I thought my coil was going away, my '95 did this a couple years ago. But it took forever to start with the bad coil.
The other thing I noticed is Idle, while not missing, is all over the place in rpm. typically 1000-1200. usually it's about 650-700. I am not sure if when the check engine light is on, the computer is telling engine to 'run home to momma', and idle is affected, or whether there is a bad sensor.
I don't have a code reader, any suggestions on what I need to buy?
I would like one that could do both my 95, and this 96. (OBD l and ll).
The speedometer works fine, I know when my speed sensor went bad in my '95 I had very similar symtoms in that truck. (missing and bucking). I will snag a code reader tomorrow, but for now any thing sound familar?
Thanks a ton guys!
Bob
Old 08-01-2010, 11:24 AM
Rep:1845
Yeah, sounds like you could have a blown intake plenum pan gasket which is causing an internal vacuum leak and your misfire. Of course it could still just be a good old fashioned misfire caused by a bad plug, wire, carbon track or something along those lines. You could always give the key dance a go and pull your codes that way for now.
Old 08-01-2010, 02:40 PM
rancherman's Avatar
Rep:171
Default key dance?
It's been awhile, but you mentioned the key dance... I remember doing that on my '87 dakota.... was it 3 on-off cycles in quick succession? and then 'try' to count the flashing 'morse code' ? After I do this, is there a code decipher somewhere in here? Thanks Remerson.
Bob
Old 08-01-2010, 03:42 PM
Rep:1845
That's the same trick. Post the codes or Google them and you'll get definitions.
Old 08-01-2010, 04:20 PM
rancherman's Avatar
Rep:171
Default code results
ok, my kid came home with the truck just now, and said it's running better. So I just took off with it and pounded on it pretty hard, and sure enough, runs very well. I did the key dance and got this:
3 flashes, pause, 5 flashes, pause, 5 flashes.
I think if it's a bad plug or wire, or dist cap... it would be there (the miss) continually.
which makes me think it's a plenum gasket too.
So happens I got an extra gasket set laying around, tonight after it cools off... will donate about 3 hours time!
Wish me luck!
Old 08-01-2010, 04:29 PM
Rep:1845
If you haven't done the cap, rotor and wires lately, this is the time.
Old 08-01-2010, 04:30 PM
rancherman's Avatar
Rep:171
ok, I found a site with the codes....and see that my first set of flashes needs to be a 2 digit number. so I either have a 1-2 or 2-1 flash before the 5 and 5.
if it's 1-2, I DID have the battery disconnected yesterday.
If it's 2-1, It's the O2 sensor staying centered. But that would be continually lit when engine is running. unless it was just a momentary condition yesterday??
Old 08-01-2010, 04:34 PM
rancherman's Avatar
Rep:171
Default tune up time
No doubt! No better opportunity to get at the dist whilst the intake is off!
later!
Bob
Old 08-01-2010, 05:06 PM
Rep:1845
I'd say you had a 1-2 most likely.
Old 08-01-2010, 08:58 PM
rancherman's Avatar
Rep:171
Default nother code!
I was driving the truck over to the shop to work on it tonight.... and it popped a new code. this time it flashes 2 different ones. first one is the 1-2: (battery disconnected within last 50 starts)43**Ignition coil circuit #Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time.
Does this mean my coil is starting to go? I am going to go ahead with the intake gaskets, plugs and wires and cap and rotor. might as well tune it all the way!
