Old 08-01-2010, 02:53 PM
skeezy1's Avatar
skeezy1 skeezy1 is offline
Vehicle: 1996 Dodge Ram Sport
Rep:92
skeezy1 will become famous soon enough
Default moved
oops wrong section........duh
http://i382.photobucket.com/albums/oo266/skeezy1_2008/The%20ram/DSC04370-1-1.jpg
Old 08-01-2010, 02:54 PM
Rep:1845
Beats me but you can check to see if the ratio is on a tag that should be bolted to the diff cover.
Old 08-01-2010, 03:09 PM
skeezy1's Avatar
Rep:92
Default Gear ratio question
96 ram 1500 5.9L auto. Whats the factory gear ratio on my truck? Want to change to help with the 22" wheels.
Old 08-01-2010, 04:18 PM
Check for a tag on the rear diff. It will have the gear ratio on it.
Or, check for a sticker on the underside of the hood. That's where I found the info on my '99 4X4. They were 3.55's.
Old 08-02-2010, 04:22 AM
skeezy1's Avatar
Rep:92
checked both....nothing
isnt there a way to check it my jacking up rearend, spinning tire counting revs. and counting revs. of driveshaft and calculate gear ratio?
Old 08-04-2010, 10:40 AM
mjonesjr's Avatar
mjonesjr mjonesjr is offline
Rep:12
mjonesjr is on a distinguished road
Here is the manual method.
1. Jack up the rear of the truck. Put the rear axle on jack stands.
2. Block the front tires
3. Mark the drive shaft and axle housing the same to determine when the drive shaft makes 1 complete revolution.
4. Put the transmission in neutral.
5. Have someone rotate a rear tire slowly while you count the rotations of the drive shaft.
6. Count the rotations of the drive shaft in 1 complete turn of the tire.
The number of times your drive shaft rotated is the gear ratio. For instance if your drive shaft rotated 3.5 times, then you have a 3.55:1 gear ratio.
1996 Dodge Ram 1500 Club Cab, 5.9L V8, 4x4
Old 08-12-2010, 05:32 AM
slimjim slimjim is offline
Vehicle: 99 4x qc150. 95.250 4x 5.9 gas
Trim Level: sport 150, slt 2500
Color: bl or gy
slimjim is on a distinguished road
My '99 sport QC 5.9 4x has 3.92s & limited slip. It may have a tow pkg to get 3.92s. It has a Reese hitch & 7 pin connector. The most common ratio is 3.55 thou.
Old 08-12-2010, 12:29 PM
Sledneck's Avatar
Sledneck Sledneck is offline
Vehicle: 1998 Dodge Ram Club Cab 2 Door
Color: Midnight Blue
Sledneck is on a distinguished road
ya my 98 4x4 is a 3.55
Old 08-13-2010, 02:06 AM
skeezy1's Avatar
Rep:92
ill deff have to try the spinning of the axle thing...
Old 08-28-2010, 12:40 PM
grumblefury grumblefury is offline
Vehicle: 2012 ram 1500
Trim Level: st
Color: bright silver
grumblefury is on a distinguished road
or you can pull the diff cover off and count the teeth on both the ring and pinion gears and divide them, for EXAMPLE if your ring gear has 32 teeth and your pinion has 9 teeth you have a 3.55 ratio
