I'm at a loss - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-01-2010, 07:50 PM
katiefly00 katiefly00 is offline
katiefly00 is on a distinguished road
Default I'm at a loss
I am totally lost on what could be wrong with this truck. We have a 1999 Ram 4x4 1500 with a 5.9L V.8. We recently acquired it in a trade. The guy we got it from said all was wrong with is was the gas gauge didn't work. Theres actually more. The gas gauge doesn't work, it stays on E most of the time, with the fuel light on. It has a full tank of gas. We'll get it started and it will die. Be driving down the road and it will die. Replaced the fuel pump/filter/sending unit and it didn't fix it. Replaced the IAC valve, it didn't fix it. Now it idles so fast that the headers glow orange-red. Sometimes the gas gauge will come on and work, but most of the time it doesnt. Also sometimes we'll get a "no bus" reading on the odometer. Replaced the battery and terminals, no change.
Also hooked up a code reader and it throws the "p0505" which means that the IAC control module is messed up. we have tried three different ones, all with the same results.
We are at such a loss on this truck, we have absolutely NO idea how to fix it. Any ideas are more than welcome.
Old 08-01-2010, 09:46 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
First welcome to the forum. Second this is just a guess but sounds like the cat might be plugged due to the glowing headers. On the gas gauge check for a bad ground, especially the chassis to frame ground which is located from underneath on the passenger side between the cab and box. Hopefully this helps.
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
Old 08-01-2010, 09:50 PM
Resident Technician
Rep:1915
IAC control module? No such animal unless you're referring to the PCM. A no bus message means the cluster isn't communicating properly on the data bus. I'd check for more than a bad ground on the fuel gauge. Check the connector at the top of the tank for looseness, corrosion or spread pins that may not be making contact.
Old 08-01-2010, 11:44 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Hello and welcome to the site!
Old 08-02-2010, 01:26 AM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
Welcome to the forum! Sorry to hear about your problem, but there's lots of people here who can help, so good luck with that and be sure to keep us posted, we want to know how it works out for you. In the meantime, be sure to introduce yourself to everyone in the Newbie Checkin and get your official Ram Z welcome!
