Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
tonneaucovered.com
Old 08-01-2010, 09:24 PM
9659ram 9659ram is offline
9659ram is on a distinguished road
Default 96 5.9 rebuilt engine won't fire
Just put a rebuilt long block in my 96 1500. Having trouble with the timing. Was wondering if anyone knows where the distributor drive gear should be positioned with cylinder 1 at tdc? The engine is not firing at all and I am stumped. It is getting fuel. Any ideas?
Old 08-01-2010, 09:28 PM
Resident Technician
Rep:1911
DISTRIBUTOR INSTALLATION
NOTE: Before installing the distributor, the oil pump drive shaft must be aligned to number one cylinder.
  1. Rotate crankshaft until No.1 cylinder is at top dead center on the firing stroke.
  2. When in this position, the timing mark of vibration damper should be under "0" on the timing indicator.
  3. Install the shaft so that after the gear spirals into place, it will index with the oil pump shaft. The slot on top of oil pump shaft should be aligned towards the left front intake manifold attaching bolt hole.
  4. Install distributor, Refer to Ignition Systems for the proper procedure.
After the distributor has been installed, its rotational position must be set using the SET SYNC mode of the DRB scan tool. Refer to Checking Distributor Position following the Distributor Installation section in Ignition system.
Do not attempt to adjust ignition timing by rotating the distributor. It has no effect on ignition timing. Adjusting distributor position will effect fuel synchronization only.
Old 08-01-2010, 10:29 PM
Rep:1625
Welcome to the forum!
Old 08-01-2010, 11:06 PM
Rep:4110
Welcome to the forum, glad you joined us here! Looks like Randy has the info you're looking for, so good luck with that and be sure to keep us posted! Any pics of your truck? We'd love to see it! Lots of great people and info here, so feel free to look around and join the conversation! Any help you need, just ask and I hope you enjoy the board!
Old 08-01-2010, 11:25 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Hello and welcome to the site! Got any Pics???
There are a lot of talented people on this site, so if you have questions feel free to ask, and I am sure someone will be able to help. If your looking for some accessories check out our vendor section and may the modding continue
http://www.ramforumz.com/forumdisplay.php?f=53
Old 08-02-2010, 09:15 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
We are glad to have you here, enjoy the board!
Old 08-02-2010, 09:18 AM
iRESQu iRESQu is offline
Rep:2217
Hello and welcome aboard the ForumZ. Glad to have you.
Old 08-02-2010, 09:54 AM
SpeedlogiX-Mikey SpeedlogiX-Mikey is offline
Rep:40
SpeedlogiX-Mikey is on a distinguished road
Welcome to the Z from BMC Performance!!!
Old 08-02-2010, 02:57 PM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
Welcome to RamForumZ, from Barrie, Ontario, Canada! Glad to have you join us here! Enjoy the site!
Old 08-02-2010, 06:06 PM
Glad you joined us and welcome to the Z for Rams from Baltimore . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question or comment . Do you have any pictures of your truck ? Have you done any mods or have plans for any ? Any of your friends have Rams ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
new engine, starting issue, timing issue
