Old 08-02-2010, 07:20 PM
Trainwreck68 Trainwreck68 is offline
Vehicle: 2012 Ram 1500, Hemi, 4X4
Color: Midnight Blue
Rep:25
Trainwreck68 is on a distinguished road
Default Annoying exhaust noise
I have a 2007 Ram 1500 with a Hemi. I have the stock exhaust system on it and under a load I am getting a "ticking" noise combined with a faint whistle. If I rev it up with it in park I can still hear the whistle a very little bit but no "ticking" noise. If I place the truck in gear put my foot on the brake and give it a little gas to simulate a load I get no unusual noise at all. I have had exhaust leaks that have done this so I have checked for an exhaust leak by having a friend block the tailpipe and listened under the truck but I hear no leaks, I even temporarily plugged the condendsate weap holes in the muffler and resonator and still have the noise. I'm wondering if this may be normal due to thin wall exhaust piping? Or has anyone else had this problem? I just bought the truck so I have nothing to compare it to, my 2001 Ram was tight and had no unusual noises at all. Any ideas would be a big help, it's driving me crazy especially with the windows down.
Old 08-02-2010, 10:38 PM
nitro1965's Avatar
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
did you buy your truck new or used. if its used maybe you might have a throttle body spacer in which can cause that whistle noise.
Old 08-02-2010, 10:43 PM
Sounds like a leaky exhaust manifold or gasket that is starting to go bad and leak.
Old 08-02-2010, 10:45 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
^^^ I agree.
Old 08-28-2010, 09:37 PM
08RamHemi 08RamHemi is offline
08RamHemi is on a distinguished road
This sounds like the same problem i am having...i only hear it when the truck is under load...if i accelerate lightly i dont hear it....i took it to the dealer they couldnt find anything wrong said it was normal...have you had any luck? its drving me crazy...they looked for broken bolts on the exhaust and said they found nothing no leak
Old 08-29-2010, 01:18 AM
chefred112's Avatar
chefred112 chefred112 is online now
Vehicle: 2005 Dodge Ram
Rep:656
are you runnin a cai with a throttle body spacer (some cai's have you install one for fitment)? especially with a stock exhaust you can hear a cai moreso which means you'll hear the valve train more...and tb spacers whistle.. my truck makes a racket under the hood but it's due to the cai and the resonance the valve train produces through it..
Old 08-29-2010, 10:03 AM
Rep:25
08HemiRam,
I did find out something about it. I posted under "Annoying exhaust noise(mystery solved). To sum it up, per a very good Dodge mechanic some of the late model Hemi's had a problem with the secondary ignition (you know the 2nd plug we have in the cylinder head) and a small amount of unburnt fuel will escape only to be ignited just prior to the converters the resulting "pop" causes the "tickin" noise. He said that it is normal and that he has been driving his for I believe 90k without insident. You are right it is VERY annoying, he said Dodge hasn't done anything about it because it is not a big enough problem to them. I guess they have done a pretty good job putting out the propaganda that all the BS noises this engine makes are "normal". If had wanted a engine with a lot of "normal noises" I would have bought a diesel. I do love Dodge products and aways have but it makes you wonder if Chevy and Ford can make engines that produce 300 to 400hp and are quiet why can't Dodge? Oh well, the cold weather will be here soon and I'll have the windows rolled up....problem fixed.
Old 11-11-2010, 12:14 PM
07ramdan 07ramdan is offline
Vehicle: 2007 Hemi Ram Quad Cab
Trim Level: Outdoorsman
07ramdan is on a distinguished road
i have the same problem and it drives me nuts!!! I had it before the CAI and flowmaster exhaust. Took it to the dealer 2 times and they said they couldn't find a leak. i was thinking of getting headers hoping to eliminate the problem and input on cheap / quality headers??
Old 07-02-2011, 10:04 PM
Torque's Avatar
Torque Torque is offline
Vehicle: 2003 Dodge Ram
Trim Level: SLT+
Color: Patriot Blue & Silver
Rep:24
Torque is on a distinguished road
Sorry to revive an old thread, but I've been searching high and low on this irritating noise. I have driving around with my windows down because of it... my truck sounds like crap driving past cars or fences while I'm accelerating. I can't recreate it revving the truck in neutral or power braking it next to a fence so it's been extremely hard for me to diagnose.
The ignition of the unburnt fuel on exhaust stroke sounds likely, but I'm wondering if anyone has found a solution. I've heard from another person that adding headers made the noise louder
Old 07-03-2011, 12:51 AM
chefred112's Avatar
Rep:656
what year is your truck? your exhaust setup?
