Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-02-2010, 10:14 PM
mjonesjr's Avatar
mjonesjr mjonesjr is offline
Rep:12
mjonesjr is on a distinguished road
Default Replacement Radiator
I noticed my radiator was leaking this evening.
What is the best replacement? Is the factory replacement from an auto parts house the best?
I have an automatic transmission if that makes a difference.
1996 Dodge Ram 1500 Club Cab, 5.9L V8, 4x4
Old 08-02-2010, 10:21 PM
Stock replacement is fine . See what options they have . Most only list one , but sometimes they will list H.D cooling . I would recommend to ya to get a new radiator cap , fresh coolant and distilled water for the coolant mix . If you have time , do a thermostat also . Nows the time to do a complete cooloing service .
Old 08-02-2010, 10:23 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Lot of times the radiator can be fixed much cheaper than buying a replacement. But that requires down time.
Brian:
Old 08-02-2010, 10:24 PM
mjonesjr's Avatar
Rep:12
Just curious as to why the cap?
I was going to do the thermostat as well. Probably go with a 180* unit.
With the new radiator I am going to route my transmission cooler lines back into the radiator before they go into the aux cooler. Any idea which line (top or bottom on radiator) is the transmission to radiator line? Who ever rebuilt the transmission before cut the radiator cooler out of the mix and I think it should be there before the aux cooler.
Old 08-02-2010, 10:28 PM
Color: RootBeer
Rep:1287
The cap is a just do it while you're at it kind of thing. Those things release based on pressure.
Its always a good idea to have a good one on there and they are not expensive.
Brian:
Old 08-03-2010, 02:37 PM
mjonesjr's Avatar
Rep:12
I picked up a replacement radiator, 2 gallons of unmixed antifreeze, 3 quarts of ATF+4 transmission fluid, and a 180* thermostat from O'Reilly Auto Parts for $219 including tax. Not too bad IMO.
Hopefully I get it all switched out today after work. It doesn't look like it will be all that much work.
Old 08-03-2010, 02:45 PM
Resident Technician
Rep:1909
Why would you NOT do a new cap unless you've pressure tested and verified your old one still meets spec?
Old 08-03-2010, 02:55 PM
mjonesjr's Avatar
Rep:12
If I have a problem after I change the radiator out, the cap will be the first thing I swap. However, where my radiator failed I would say it is a safe bet that it wasn't because of the cap not holding pressure.
Old 08-03-2010, 03:12 PM
Color: RootBeer
Rep:1287
You're missing the point. If the cap is not releasing pressure, it could cause the radiator to blow out.
Brian:
Old 08-04-2010, 10:37 AM
mjonesjr's Avatar
Rep:12
I stopped and picked up a cap as well.
I got it all replaced last night except for the thermostat (didn't have time to tear into getting the housing off). It was easier than any other radiator that I have swapped in other vehicles. Took me about an hour from start to finish.
The truck seems to run a bit cooler now as well.
