Old 08-03-2010, 08:38 AM
vtxcowboy's Avatar
vtxcowboy vtxcowboy is offline
Vehicle: 2006 Dodge Ram 3500 Cummins
Trim Level: Free
Color: dark red
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
vtxcowboy is on a distinguished road
Default bag question
im gettin a 3500 that has bags on the rear and i know what they are for but need to know more about them. a air compressor is used to air them up manually so i do it everytime besides pushing a button or how ever else it is done. how much air is needed in them for pullin 24 ft gooseneck loaded with hay? any info on the bags is much appreciated
Old 08-03-2010, 02:32 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Its different on every truck. You'll see it level out when you begin to inflate the bags. I run and recommend running as little as possible so you dont get beat, the bags full of air can be a rough ride.
Does it have a tank valves and compressor on board or is it manual fill at the gas station?!
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 08-03-2010, 10:29 PM
I push the skinny pedal
Rep:3277
^^ what he said. They'll begin to level based on the weight you're hauling. My SuperDuty has the firestone bag set up and I normally get level around 38psi when hauling my bulker trailer, but it's 150psi when hauling my QC tri-axle, makes for a rough ride, but I'd rather not be squatting when I pull through the scales.
Kurtis
Old 08-03-2010, 11:16 PM
vtxcowboy's Avatar
Trim Level: Free
Color: dark red
fill at the pump. well around how much usually makes them bust or how hard is it to bust them?
Old 08-04-2010, 06:18 AM
Rep:3277
I'd look at a 2600# bag, and you honestly have to put a full load bottoming out at high speed to blow a bag like that. Now, the most important thing is to mount them so there's no sharp edges or shot surfaces nearby or that'll spell the end of the bag right quick.
Kurtis
