tonneaucovered.com
Old 08-03-2010, 12:42 PM
PowdaSuga PowdaSuga is offline
PowdaSuga is on a distinguished road
Default Vibration, any ideas. Dealer didn't have any clue.
Well my truck has a slight/moderate vibration reverberating through the pedals and steering wheel/column. It happens at any speed. The best I can tell is that it happens when the ECO light comes on. I took a test drive with a shop foreman at the dealer and he didn't know what it was. He said "I haven't driven enough of these to know if it's an inherent problem." Anyone else having the same problem or any idea as to what it might be.
Old 08-03-2010, 12:54 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
I am just going to guess and say its just a vibration because half of your cylinders are becoming compression release cylinders with no function, as, when the ECO light comes on, it becomes a 4 cylinder for gas mileage.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 08-03-2010, 01:00 PM
Resident Technician
Rep:1911
Are we even sure the truck has a Hemi? If so, when it goes into MDS mode, compression isn't released. The valves stay closed and the air in the cylinders remains trapped, acting as an air spring until MDS is deactivated.
Is the vibration noticable only while driving the truck or do you feel it while stopped in or out of gear?
Old 08-03-2010, 02:59 PM
Sorry I should have mentioned the engine size. It's the 4.7 (non-hemi). I only notice it when driving, it does not display the same behavior when idle.
Old 08-03-2010, 03:10 PM
Resident Technician
Rep:1911
Sounds like you either need to call Chrysler customer assistance or find a new dealership.
Old 08-03-2010, 07:02 PM
crash2000 crash2000 is offline
crash2000 is on a distinguished road
lost a wheel weight? mud inside the rim? shifted tire belt?
Old 08-03-2010, 08:42 PM
MAP71 MAP71 is offline
Vehicle: 2010 1500 crew cab
Color: Deep Water Blue Pearl
MAP71 is on a distinguished road
If 4X4 could be cv joint. Any off road use or hit any big ass pot holes? Bent a wheel, shaft or broken motor/trans mounts. Over heating breaks can warp rotors.
Just a few that come to mind.
