2010 Ram SPORT HID NEED INFO - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-05-2010, 07:19 PM
onewheelregulator's Avatar
onewheelregulator onewheelregulator is offline
Trim Level: Sport 4x2
Color: Mineral gray
onewheelregulator is on a distinguished road
Originally Posted by JaredConspiracy View Post
go with ddmtuning.com (no need to pay premium prices for hids. theyre old technology so buy em from a wholesale dealer)....get 55 watt kitts because the wattage is the same as a stock 55 watt halogen bulb so the computer system will be less likely to give you trouble with them.
heres the link to the kits:
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
should i also buy the harness when purchasing these?
15%tint, Daystar 2" level, Flowmaster 40 w/ deleted resonators, Helo 866 24's
Old 08-05-2010, 11:01 PM
MSPTNY02's Avatar
MSPTNY02 MSPTNY02 is offline
Vehicle: 2010 Ram 1500
Color: Mango
Rep:14
MSPTNY02 is on a distinguished road
check out my pics at car domain. install was easy and def worth it. lights are a lot brighter and i have never gotten flashed for them. hanh and 3b-spec are great!!!!
http://www.cardomain.com/ride/3853324
Old 08-06-2010, 01:56 PM
JaredConspiracy's Avatar
JaredConspiracy JaredConspiracy is offline
Rep:243
JaredConspiracy has a spectacular aura aboutJaredConspiracy has a spectacular aura aboutJaredConspiracy has a spectacular aura about
it wouldnt be a bad idea! To be quite honest ive heard of people needing harnesses...and not needing them. what i'd do is buy the 55 watt kit and the harness. try plug and play first. if it works...be thankful! if not...go with the harness.
Old 08-06-2010, 02:01 PM
Rep:243
what I did to get my hids consistantly running with no bulb out readings on the dash is......i bought the kit and a relay harness. connected the power and ground the usual way. but the unusual thing i did is for the two signal wires, instead of plugging them into my headlight harnesses, i t-tapped them into my running lights. that way when i would turn my running lights on, the harness would begin to draw power for the hids. Then, i cut the positive signal wire and ran a toggle switch into it that is now located on my dashboard. So, when i want running lights i turn the knob as usual. then when i want headlights i flick the switch. it's kinda rigged up, but id rather have my shit work consistently and not flicker or shut off randomly.
BUT! i used a 35 watt kit. and when i hooked up HIDS to my friends 2006 ram (which may have different diagnostic systems then the 2010's), he was able to plug and play a 55 watt 6000k slim ballast ddm kit (like i showed you) with absolutely no problems. which is why i would recommend that to you first.
Old 08-06-2010, 06:06 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Here is a write-up I just did for installing HIDs. Should help you out, its a cake walk.
http://www.ramforumz.com/showthread....490#post277490
2015 Camaro 2SS/RS/1LE
Old 08-06-2010, 09:53 PM
MSPTNY02's Avatar
Color: Mango
Rep:14
35w w/ harness in a quad headlight is just enough IMO
Old 08-07-2010, 12:44 PM
alittlepage24 alittlepage24 is offline
alittlepage24 is on a distinguished road
jaredconspiracy i see you driving all the time dude, you were at the kbl last sunday night huh? maybe you can help me getting my lights working right haha.
Old 08-15-2010, 10:24 PM
Simcik Simcik is offline
Vehicle: 2010 Ram 1500 Quad Cab 4x4
Trim Level: Lone Star
Color: Light Graystone
Rep:20
Simcik is on a distinguished road
Got my 5000K HID Lows and Fogs off of eBay for $67 total. This included plug and play harnesses, ballasts, and a capacitor needed to keep them from flickering.
Installation was a breeze, took less than an hour for all lights. Mounted the ballasts using existing holes in the front frame work of the truck. Am looking into getting HID highs too, as the responce time is not a delayed as I was orignally told, and would still allow for the full use of the Optic Horn (Flash-to-Pass Highbeam) feature.
Old 08-16-2010, 12:07 AM
doz doz is offline
Rep:76
$67 for lows and fogs? I hope they came with a warranty...
Old 08-16-2010, 12:41 AM
Rep:20
Lifetime Replacement! No probs. yet though...
