4.7 engine noise tapping at startup - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-05-2010, 07:50 PM
jglu3 jglu3 is offline
jglu3 is on a distinguished road
Default 4.7 engine noise tapping at startup
My engine has a serious engine tapping noise when I start it up but go away in about two minutes. Even when it goes away and I rev the engine and than take my foot off the pedal it sounds like a little rattling going on. I am thinking the lash adjusters bleed down while it is sitting. I am considering replacing them and am wondering if anyone has this noise and replaced the adjusters. It did not leave the factory with this problem so something has worn. Its a 2002 with 105000 miles on it.
Old 08-05-2010, 08:06 PM
I would like to add that I already install a new timing chain set and when they did that job I was told that the engine was very clean up top and it appears the oil changes were kept up with. I also tried a flush with mystery oil a few times. I am the second owner and bought it from a small used car lot.
Old 08-05-2010, 09:36 PM
I just checked with a junk yard I have dealt with . They have 2 used engines : model year specific with a 16 tooth crankshaft tone wheel . 42,000 mile engine for $2150 . Expensive little bugger . 89,000 mile for $1850
Old 08-09-2010, 10:45 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
mine does the same thing, but now it will be there some days and fine other days. Its getting so annoying that im losing my mind over it, i actually thought of pushing it off a cliff and get the insurance money haha.
Somebody help!
and over 2k for a motor might as well swap a 5.7 in it and call it a day
Old 08-09-2010, 11:13 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
How's the oil pressure? Sounds like the pump is not getting the oil up to the top of the engine fast enough.
Brian:
Old 08-10-2010, 12:42 AM
lt173 lt173 is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: SLT Plus
lt173 is on a distinguished road
Don't want to be the bearer of bad news...............but on an 05 1500 with a 4.7 I had we took the valve covers of due to the loud knocks just to have a look see. Two rockers were just lying there guess due to sludge, bad push rod etc we snapped them back in which wasn't as easy as it sounds, then I traded it in for a 2010. True story.
Old 08-10-2010, 08:12 AM
Resident Technician
Rep:1915
The reason it spit the rockers out is because you had valves sticking. The 4.7 doesn't have pushrods.
Old 08-10-2010, 10:51 AM
Cool
Thanks for the correction, pardon the error. Am I correct in saying the valves were sticking due to the sludge? This truck saw regular oil changes. Shortly after this it started to blow anti-freeze, turned out to not be a head gasket but warped head, as well as warped intake manifolds. Techs at Chrysler said it didn't have blue on it representing a major over heating. Just that it happened over time motor had 170,000 K 80% highway. Truck did very little work under load. Never had any issues till the big one. My guess is in the 05 the motor was simply underpowered for a full size relatively heavy unit. As well I put 275's on and in retrospect I'm sure this didn't help.
Reason I bring this up is the start of my problems seemed to be the rockers, although I don't know if the two were related I did very well on trade. And love the new Hemi, even though I had the problem still stuck by the Rams.
Old 08-10-2010, 11:46 AM
Resident Technician
Rep:1915
Sludge is the most likely culprit. Since you said the oil changes were regular, I'd suspect either the truck simply wasn't worked hard enough to burn off all the combustion by-products or possibly the brand/grade of oil may have contributed to the demise of your 4.7. I do tend to agree that the first gen 4.7 really wasn't enough motor to really motivate the Ram down the road.
Old 08-10-2010, 04:55 PM
The oil pressure gauge jumps right up to high as soon as it starts. When the timing chain set was done the top was spotless (stopped by that day and also seen for myself) and they also said the engine had for sure seen regular oil changes.
