Old 01-25-2013, 11:36 AM
maverill maverill is offline
Vehicle: 2002 Dodge Ram 1500
maverill is on a distinguished road
Try running a synthetic blend oil or pure synthetic in your engine. I had the same issue and started out with Castroil synthetic blend and now use amsoil pure synthetic and the noise has disappeared at start up.
Old 01-25-2013, 11:41 AM
Default try synthetic oil
Also running pure synthetic makes my truck run like it was new again.
I have heard it can help gas mileage also but I am not sure about that yet. Also gives you 10,000 miles between oil changes with Amsoil.
Old 01-25-2013, 03:33 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Hey Rigor. These motors have a habit of braking exhaust bolts. Have a look around the manifolds and see if yours has a few broken.
Old 04-19-2013, 11:13 PM
cmartmanD1500 cmartmanD1500 is offline
Vehicle: 2006 Dodge Ram 1500
cmartmanD1500 is on a distinguished road
Lightbulb
Originally Posted by jglu3 View Post
My engine has a serious engine tapping noise when I start it up but go away in about two minutes. Even when it goes away and I rev the engine and than take my foot off the pedal it sounds like a little rattling going on. I am thinking the lash adjusters bleed down while it is sitting. I am considering replacing them and am wondering if anyone has this noise and replaced the adjusters. It did not leave the factory with this problem so something has worn. Its a 2002 with 105000 miles on it.
Myself I get agravated with that tapping noise, I tried marvel, fresh oil change. My engine only has 80,000 miles. It sees to me it must be a low oil flow to one of the lifter rods or defect in oil port molding process casting of the engine. I'd really would also like a straight answer from a Dodge engineer. I hear too many complaints. I had trucks with 250,000 miles and had solid sounding engines with out a tick, click or smoke.
HMMMMM? Let me know if you get the correct fix? Thanks, I'm in the same boat! Have a good week end!
Old 04-19-2013, 11:17 PM
I will look at my manifold bolts tomorrow, if this is what is causing a lifter sound, I will be very surprised and thankfull for your advise if this is the case!
Have a good one!
Old 05-01-2013, 11:18 AM
crazyclown crazyclown is offline
crazyclown is on a distinguished road
Mine has the same tapping issue on startup but after warming up it is fine. The only issue I have had with it is I have cracked four spark plugs in the last year always the same cyclinders 1 or 5.
