Old 08-06-2010, 03:27 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
Default no power to condenser motor / it's all *%$&'d up
ok, had intermittent issue where a/c at idle would stop cooling followed by a hiss in the passenger side - idle would get rough
-a/c has good charge
same problem, again intermittent. noticed condenser motor doesn't turn, spun blade and motor kicked in. thinking the motor was going bad i replaced it - semi truck a/c mechanic friend of mine takes gauges to truck, charge is good
cooled for a little, fan chugging away... then - same problem only not intermittent anymore. compressor cycling, rough idle, hissing from passenger side, condenser motor will not spin. relays good, fuses good
on the high side line, there is the pressure transducer. there is a film of refrigerant oil on it, seems to be seeping from seam on the metal part of switch.
should i look to this as the culprit - will it cause condenser motor to get no power. at a complete loss, am i to admit defeat and bring it to a shop?
Old 08-06-2010, 08:09 AM
Rep:1909
Fuse 12 in the IPM powers the 30 and 85 terminals of the condenser fan relay. The PCM controls the relay on the 86 terminal and power is sent to the fan via the 87 terminal and the fan has a chassis ground. You need to check the operation of the relay and PCM first.
Old 08-06-2010, 06:21 PM
Trim Level: sxt
Rep:197
well, the truck beat me - the new condenser motor died, brand new motor >
having a guy install the new assembly from mopar as well as charge the system to all the appropriate levels. on my way to pick it up in a few...
Old 08-06-2010, 11:42 PM
Well is it fixed?
Old 08-07-2010, 04:56 AM
Trim Level: sxt
Rep:197
so far so good - got down to 37 tonight. going back to checker to exchange their chinese made junk motor for my good american cash...
Old 08-07-2010, 09:05 AM
Good to hear it's fixed again especially when it's as hot as it has been . .
Old 08-07-2010, 09:41 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Mine went out recently as well......100,000mile elite wrap warranty, it goes out at 107k. $700 and some change later, cooling, but not like it used to be. I guess the whole recover/recharge thing was done improperly. Not as much put back in, or possibly too much, who knows...
Old 08-07-2010, 12:52 PM
Trim Level: sxt
Rep:197
the motor can be put in without evacuating the system - when the truck was at the shop, i opted for the oem unit. we had been playing with the freon so i also had them do an ac service - out the door was 375
Old 08-07-2010, 01:04 PM
Trim Level: Custom
Rep:1648
Well it's what I figured, and this was at a Dodge dealer (Not my regular dealer btw). I couldn't see why they had to do the recover/recharge either, and on top of that, they replaced the condenser motor SHROUD??? WTF?
Needless to say, my Ram or SRT8 will not be going to them for any service whatsoever while I am here in Florida. I will make the drive to the next town....
I forgot, I did have an injector service done at the same time.....
Old 08-08-2010, 04:16 PM
Trim Level: sxt
Rep:197
the motor and shroud are a new design which is why they probably changed both.
on the stock shroud there is a piece of plastic that the ac line runs through making removal without evacuating impossible. if you cut the plastic part out, the shroud comes out without havng to do that. the factory condenser motor comes out with the shroud.
the motor kit my shop got had the motor, shroud and new fan blade (68004163ab)
