United Radio
Old 08-06-2010, 04:07 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
Default flashing check engine light at freeway speeds
well today i was late for the dentist and i jumped on the freeway and at around 75 and 3500 rpm my check engine light started flashing and went away once i let off the gas an it shifted. and when u put the key an turn it right before you start it my check engine light stays on. anybody have any ideas or what should i do
Old 08-06-2010, 04:11 PM
Rep:1824
Pull the codes. I'm betting on a P0300-P0308.
Old 08-06-2010, 04:18 PM
Rep:53
how do i do that?
Old 08-06-2010, 04:31 PM
NCDEVILDOG's Avatar
NCDEVILDOG NCDEVILDOG is offline
Vehicle: 2001 Dodge Ram
NCDEVILDOG is on a distinguished road
Send a message via Yahoo to NCDEVILDOG
go to autozone or advance auto and ask them to check your codes with a code scanner. its a free service they have. If you have a power programmer you could use that also to pull codes.
semper fi to all my brothers out there!
Old 08-06-2010, 05:35 PM
Rep:53
thank you! i went to pep boys and its throwing only one code PO301.
Old 08-06-2010, 09:44 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
dang, randy you're good. so, what does it mean all powerful dodge guru?
Kurtis
Old 08-06-2010, 10:11 PM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2012 dodge ram
Trim Level: sport
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
ya randy what does it mean
2012 ram sport qc
Old 08-06-2010, 10:36 PM
Rep:53
i read its cylinder #1 misfire.
and to make me look even worse i cant find the damn spark plugs??
Old 08-08-2010, 11:39 AM
Rep:1824
An individual ignition coil (1) is used for each spark plug. The coil fits into machined holes in the cylinder head. A mounting stud/nut (3) secures each coil to the top of the intake manifold . The bottom of the coil is equipped with a rubber boot to seal the spark plug to the coil. Inside each rubber boot is a spring. The spring is used for a mechanical contact between the coil and the top of the spark plug. These rubber boots and springs are a permanent part of the coil and are not serviced separately. An O-ring is used to seal the coil at the opening into the cylinder head.
1.Depending on which coil is being removed, the throttle body air intake tube or intake box may need to be removed to gain access to coil.
2.Disconnect electrical connector (2) from coil by pushing downward on release lock on top of connector and pull connector from coil.
3.Clean area at base of coil with compressed air before removal.
4.Remove coil mounting nut (3) from mounting stud.
5.Carefully pull up coil from cylinder head opening with a slight twisting action.
6.Remove coil from vehicle.
Old 08-09-2010, 01:01 AM
Rep:53
sweet thanks man your a life saver you've helped me with a couple problems already! ill pull it tomorrow if i have time. would this misfire result in bad gas milage?
