Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 08-06-2010, 05:24 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default Adding Power Adjustable Pedals and Climate Control?
Just curious.
2 things my Laramie had that I really enjoyed were the power adjustable pedals and the digital climate control. So, can these be added to my Big Horn? If so, how much for each?
Brian:
Old 08-06-2010, 05:29 PM
I'm not sure it could be done at a reasonable cost . Thats pretty extensive there .
Old 08-06-2010, 06:27 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
This is a pretty common discusion among people from the new cars trucks and jeeps. the simplist answer is you have to have the ability to change different set options in the TIPM if the TIPM says not set for power adjustable pedals there is no way to change it to set in other words if the TIPM says the truck didnt come with that option it wont control that option whether its there or not. If chrysler gave us all the build codes to use in added options in dealerconnect or access on the witech to change settings it would be possible alltho the auto climate control would be pretty pricey you would have to change the entire housing and the dash wiring is different as well as the obvious controller. Looking thru the TIPM config. there's options in there that are not even offered like HID lights, Keyless Go and some others the only thing that I have been able to add to my SLT is the homelink module because its not controlled by anything. with that said I did find some things that you can add but not to just any truck my next project is changing my plastic steering wheel to the leather wrapped one that has radio controls the codes are there to add this option but I'm not sure about the wiring yet I haven't torn it apart yet but I will keep you guys posted I also found and completed I think to be the first Ram ST with keyless entry and remote start like it came from the factory chrysler says its impossible...
Old 08-08-2010, 08:29 PM
Color: RootBeer
Rep:1287
So, how do I find out if the TIPM would accept the adjustable pedals and if it does, how much would it cost to add them?
I can understand about climate control and can live without it. But the pedals would make driving the truck more comfortable if they can be added.
Brian:
Old 08-09-2010, 10:30 AM
Trim Level: R/T
Color: Gray
Rep:145
If it wasn't built with it from the factory the factory setting would be not set the problem with that is there is no way to change that setting...
Old 08-09-2010, 11:17 AM
My ss got a ls's Avatar
My ss got a ls My ss got a ls is offline
Vehicle: 2010
Trim Level: laramie
My ss got a ls is on a distinguished road
to change out for prower pedals you would have to change out the whole wire harenes and break sled and also reprogram the computer as all of this is different from what you have now
If you cant dodge it ram it
Old 08-09-2010, 12:48 PM
Trim Level: R/T
Color: Gray
Rep:145
Theres no way to reprogram the computer...I wish there was I would be on it...
Old 08-11-2010, 02:17 AM
Vehicle: 2010
Trim Level: laramie
the dealer has ways to getting into your computer and reprogram it i think it is a witech
Old 08-11-2010, 08:49 AM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
If it could be done, I think it will be very expensive.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors.
Future Mods: What ever I can sneak by my wife.
Old 08-11-2010, 09:29 AM
Trim Level: R/T
Color: Gray
Rep:145
I work with the witech daily I work at a Dodge Dealer I wish we had ways to do that the only people that have access to do things like that are chrysler engineers.. our version of the witech and starmobile is designed just as a diag. and test aplication we have very limited access to change things..
