Old 08-06-2010, 07:04 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:72
doz will become famous soon enough
Default HID Install 09/10 RAMS
So I see alot of people wondering if they can install HIDs and if so, how. Well, one of my ballasts died so I had to pull it out today. Figured Id snap some pics, dont mind the dirty truck it needs a bath this weekend. This is the kit from 3bspec (although most are the same I believe).
First, remove the plastic shroud ontop, 6 plastic push tabs. Gently pull them up
Next, remove the 4 - 10mm bolts holding on the front grill. Once those are removed, gently pull from the bottom of the grill out and the 3 push tabs on the bottom will release.
Now remove the 2 - 10mm bolts holding the headlight inplace. **DONT TRY TO PULL THE HEADLIGHT OUT YET!!**
Next goto the wheel well and pull back the cover (its a plastic push pin again). With this removed, you can access the plastic slide that holds the headlight inplace. Push it up (yes, it sounds backwards) to release it. Dont force it if its stuck, just jiggle it a little and itll free up (you can move the headlight a small amount if needed to free it).
With the headlight now removed (just disconnect the plugs, self explanatory), you can install your ballast/relay. I chose to use 3m super strong double sided adhesive tape. It holds well. Be sure to clean BOTH surfaces to ensure no dirt is inbetween. Our trucks have the perfect spot for them to be mounted as well!
Now youll need to install your new bulb and harness into the housing. Youll need to drill about a 1" hole in your headlight bulb access cover as you can see in the pic. Mount the new bulb and insert the connectors as shown into the factory. Also below youll see how to route the wiring harness (from 3bspec site). I taped the connectors to ensure they would stay in place (and to protect the terminals, you can also use some dielectric grease on it as well).
Completed wiring w/ the cap on. It seals up nicely (I havent had any issues with this kit or any others using the supplied grommet).
Next make all your connections, I chose to zip-tie my wires together before I shoved it back in. Be sure your connections are routed to the inside of the headlight so it doesnt hit the frame behind it.
Install everything reverse order. All you need is a 10mm socket and ratchet to complete this as far as tools go. Get some dielectric grease (optional), electrical tape, and a few zip-ties and you are good to go!
DS Trinity, S&B Intake, ARH LT Headers, Magnaflow Cat-back, 87mm PTB, BT Catch Can, 180* T-Stat, v6 E-Fan, 5000k RS HID, XD Misfits w/ 35"x12.5"x18", Rancho QL level, 5% tint w/ 35% full windshield
Old 08-06-2010, 07:16 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Nice write up, well done. Reps to ya...
Old 08-06-2010, 09:13 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
GREAT write up, both instructions and pics!
(Where were you 3 months ago when I was starting my own HID install? If I'd have had your write-up then it would have spared the neighborhood hearing a whole bunch of cussing coming out of my garage.)
Rep to ya!
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 08-07-2010, 12:00 AM
Rep:1625
Nice writeup!
Old 08-07-2010, 02:27 AM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
Nice job!!
Mike
'04 Ram
"Yea its got a hemi!"
Old 08-07-2010, 10:18 PM
doz doz is offline
Rep:72
Thanks for the good words. First write-up Ive ever done, so theres room for improvement with the next one for sure.
Old 08-12-2010, 04:30 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
nice write up man i really want to get H.I.D's for my 09 sport where did you get them from? and can u post up a pic of them turned on and some night shots plz?
Old 08-12-2010, 04:50 PM
Nice write up . Thanks for the help . Rep ya .
Old 08-12-2010, 04:51 PM
Can't rep ya yet . But I'll remember and get ya later .
Old 08-12-2010, 09:58 PM
doz doz is offline
Rep:72
Ill get the shots, I just got my replacement ballast in late last night, all good again
Got them from 3bspec. Just goto www.3bspec.com They used to be a vendor here, but operatic left for the time being. Hanh is the owner and is a great guy. He took care of my ballast issue quickly without any problems (overnighted it to me, prepaid ship label to send the bad one back, class act right there).
If you use the coupon code RAM you should get the $100 HID kit w/ the relay harness so theres no flickering issues! Id definitely recommend Hahn and 3bspec!
