Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-06-2010, 09:04 PM
vsanks vsanks is offline
Vehicle: 1996 Dodge Ram 4x4
vsanks is on a distinguished road
Default Calalytic Converter Woes
Well…the catalytic converter on my ’96 Ram’s gone bad at 75K. It’s rattling. Time to get a new one…and I know nothing about what I’m about to do.
I see that Magnaflows are popular on the forum. Can I go to a muffler shop and ‘assume’ they’ll put the right Magnaflow converter on…and does that make a difference…or are aftermarket converters universal? Is there any chance my check engine will flash after installation of the new converter? And lastly, does a new converter include new ‘ports for the o2 sensor? Thanks for any help!
vsanks
Old 08-07-2010, 12:33 AM
The muffler shop will beable to hook ya up . If you were to take it to the dealer it would entail replacing the Y-Pipe . Quite expensive .
Old 08-07-2010, 12:45 AM
TenneSST's Avatar
TenneSST TenneSST is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
Color: Black/Silver stripes
Rep:134
TenneSST will become famous soon enoughTenneSST will become famous soon enough
I ordered my Magnaflow Y pipe and converter kit from Summit Racing. It has bungs for both oxygen sensors. It was a fairly simple installation. Your check engine light will not come on because of the Magnaflow converter.
Kevin I.
http://www.ramforumz.com/image.php?type=sigpic&userid=5052&dateline=1301683  967
Your local shop can hook you up. And a good catalytic converter doesn't have to be a Magnaflow. Most shops carry Walker or TRW cats which will work just fine.
All cats come with what you need to keep from getting a code as they have provisions for O2 sensors.
Old 08-07-2010, 08:14 AM
Thanks for the info. I'll be headed to the muffler shop on Monday.
Old 08-07-2010, 11:18 PM
beermanjoe's Avatar
beermanjoe beermanjoe is offline
Vehicle: 2007 Ram
Rep:25
beermanjoe is on a distinguished road
Probably just the heat shield rattling. That`s what it was on an old Ford truck I had.
Old 08-07-2010, 11:29 PM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2012 dodge ram
Trim Level: sport
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
ya are you sure it is done for most times you dont need to replace them till there just about pluged my buddy has 160,000 miles on his and he had the same noise and it was the heat sheild if you are not throughing any codes it might not be your cat at all have them check it out first before they do anywork or sell you something you might not need
2012 ram sport qc
Old 08-08-2010, 09:33 AM
Thanks for the advice. I've tried and can't seem to make the heat shield rattle. I did put a mechanic's stethoscope to the converter. When you do, the rattle seems to be inside. I'll get it checked first, though!
Old 08-08-2010, 11:30 AM
Rep:1845
You don't need a steth, just a rubber hammer. Give the converter a couple of shots and if you hear a rattle, the catylist inside is shot.
Old 08-08-2010, 12:48 PM
Trim Level: sport
Rep:108
and this works also
2012 ram sport qc
