Old 08-07-2010, 08:46 PM
BlueLightning's Avatar
BlueLightning BlueLightning is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Big Horn
Color: Blue
BlueLightning is on a distinguished road
Default Tow/Haul Mode
Tow/Haul Mode
Can someone help me? I read the manual on how to operate the tow/haul mode but I canít seem to get it to work. I put the truck in drive, press the tow/haul button, get the gear indicator (5), but I canít change the gear when I press up or down?
Am I doing something wrong? Is there a trick to this or am I just an idiot?
Thanks,
Pete
Old 08-07-2010, 09:02 PM
10ramisport's Avatar
10ramisport 10ramisport is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: Sport 4x4
Rep:73
10ramisport will become famous soon enough
The last time I used the tow/haul mode, I just pressed the button, it lit up "tow/haul" on the lower right side of the instrument cluster and had a 5 next to the cruise control display while on the highway. Also the -/+ was lit. HTH
Old 08-07-2010, 09:23 PM
Color: Blue
That's what mine does too but I can't get the +/- to work to select a lower maximum gear?
Old 08-07-2010, 09:38 PM
Rep:73
Not sure if you can manually select to a lower gear while in tow/haul mode. Never had the need to. Maybe someone else can chime in.
Old 08-07-2010, 09:55 PM
agjames agjames is offline
Vehicle: 2010 , crew cab, 1500
Color: inferno red
agjames is on a distinguished road
i understand it removes the lock-up in the trans.... and takes the shifting over on its own...
Old 08-08-2010, 09:03 AM
Color: Blue
What's the +/- on the shifter for?
Old 08-08-2010, 09:16 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I have never tried manual shifting in tow/haul, perhaps its disabled by design.
Old 08-08-2010, 11:12 AM
Color: Blue
The Owner's manual says that you can limit the top gear with it, so if you choose 3 it won't shift past 3. At least that's how I interpreted it. Is this another function that isn't what it seems like such as the u-connect buttons on the radio?
The only reason I'm asking is because I assumed this was similar to the Toyota Tundra I test drove before the Ram. You were able to select and stay in any gear.
Old 08-08-2010, 12:05 PM
My Chev Silverado crew cab diesel with the Allison trans had a +/- switch on the shifter handle that I could use, in tow/haul mode, to select a gear up and down, much like the AutoStick function MOPAR puts on some vehicles.
However, I have not checked how the transmission in the new MOPAR trucks is arranged or why they have a +/- indicator in the display.
Maybe this is an excuse for me to go to the local Dodge Garage and check out a new truck.
Old 08-08-2010, 01:24 PM
crash2000 crash2000 is offline
crash2000 is on a distinguished road
Originally Posted by BlueLightning View Post
Tow/Haul Mode
Thanks,
Pete
I'm reading it different, and there 2 different systems, the +/- on the slector has nothing to do with tow/haul, page 309 in the owners manual talks about it.
