Old 08-08-2010, 01:26 PM
Iamahemi Iamahemi is offline
Vehicle: 2012 Ram Power Wagon
Color: PW7
Rep:58
Iamahemi will become famous soon enough
To select the gears in tow/ haul +/- just move your gear shifter side to side when in "D" . That's how it works in mine. My shifter is on the console.
2012 PW bright white,Leer cap,Bedrug,2010 rear headrest swap,black Mopar side steps, debadged
Old 08-08-2010, 11:28 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
It does'nt matter if your in Tow/Haul or just in Drive. Just move the shifter left or right to shift up or down
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 08-09-2010, 07:11 AM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
Does not matter if your in D or D T/H mode
You should still be able to select your gear by going L-R
If you can't, its back to the dealer you go
Old 08-09-2010, 02:02 PM
Revolter's Avatar
Revolter Revolter is offline
Vehicle: 2012 Ram 1500 SLT Crew
Trim Level: Texas Edition
Rep:87
Revolter will become famous soon enough
I beleive what Tow/Haul mode does it puts it in 5 to turn off the MDS and it also holds the gear longer than normal. you will also notice the RPM's stay higher too when driving at about 2000RPM. When you slow down it shifts to a lower gear to help breaking. To be able to shift in different gears you have to put it in the +/- mode.
09 SLT CC, Longhorn, 5.7, 3.21 Gear, Dodge Chrome Sidebars, Factory Duals, K&N, Tint, Xtreme Spray Bedliner.
-Ken-
Old 08-09-2010, 10:00 PM
BlueLightning's Avatar
BlueLightning BlueLightning is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Big Horn
Color: Blue
BlueLightning is on a distinguished road
Question
Just to clarify, I have a column shifter. I re-reread the owner's manual again and am still trying to figure out what I'm doing wrong. I put the truck in D and tried the +/- on the shifter without any results and pressed the tow/haul button and tried the +/- without results. I guess I either have something wrong with the truck or I need to do something different.
Unless anyone has some insight to what I'm doing wrong my next step will be to call Dodge.
Thanks,
Pete
Old 08-09-2010, 10:31 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Vehicle: 2010 RAM 1500
Trim Level: Quad Cab 4X4 Sport
Rep:2453
I just tried mine today out of curiosity. It works as Revolter has stated. Press Tow/Haul and you can still move shifter to the +/- mode. At this point you can manually change gears with a push left or right. If you not able to do this I suggest a trip to the dealer is in order.
BT CC / Hood Kit, LED Tails, Recon 3rd Brake & Xtreme LightBar, Black Aluminum Side Steps, Leer 700, DeeZee Tailgate Assist, MOPAR Valve Caps, Lighted RAM hitch cover, Front Tow Hooks and Bed Post Hide-a-Hooks, Tints (20% frt, 35% rear and slider), Painted Engine Cover/Brake Calipers, K&N Drop in,OEM Fender Flares/ bug deflector, FM 40, SC Cortex, Oracle H11 LED Heads, 4000k Putco Fogs, LED Interior Lights, Honeycomb Grill, Bilstien 5100's.
Old 08-09-2010, 11:33 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The +/- button on the shifter should change the display to show the highest gear the trans will shift to.....irregardless of whether or not you are in tow/haul. If it does not do this, you have warranty which fixes it for Free!
Hehe....my buddy just took his 'Really Good Deal' to the dealer for a new trans......it's gonna cost him $5000 by time the dust settles. He could have bought a 'New' truck with warranty for $8000 more than his 'Good Deal'. I just can't bring myself to console him.....he hassled me for a month about buying a new truck just for the warranty.
brad
Interested in one of my mods?
Old 08-10-2010, 12:32 AM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
On a Column shifter in Tow/Haul mode can't you just use the +/_ button on the column to toggle the shifts if you like.
Old 08-10-2010, 09:41 AM
Rep:2583
Talking
i was informed about 40 days ago, just before my cross country trip, by Randy & others
the new vehicles trannies shift selection is as follows:
position 0ne truck uses only first gear,
position 2 starts in 2nd & will stay in 2nd, up until a certain engine RPM is hit, then it shifts itself to 3rd, so that you can Not destroy the engine
positions 2 thru 5 is the same as manual selection, if the 5 is selected & not moved, FIRST gear is not used, you take off in position 2 & it will shift up as normal.
Using this method, you are in control of your shifts, up to the point that the computer senses Maximum Overload Will Rogers.
Once position [U]SIX[/U} is selected, again FIRST gear is NOT used, you start off in 2nd & it shifts itself at preset RPMs, this is computer controlled
you can chose to manually shift your transmission like a B & M hydro stick, going from position 1, then 2, then 3 etc., or go from position 5, down to 4, 3, 2, 1, but,
once 6 is selected, the transmission is in charge, this also allows the MDS to start functioning
if a tuner chip is installed, the shift points can be changed
if i inserted any incorrect info, feel free to correct it, we can't have any one doing bad things to their vehicle because they took this as gospel
Old 08-10-2010, 10:38 AM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
Agree with GT Yankee, Tow/Haul mode stops the truck from going into MDS and keeps the vehicle in 5th gear. This will reduce the load on the engine. As for not being able to manual shift while in tow/haul mode I am going out for a burn in the truck and I will post the results.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors.
Future Mods: What ever I can sneak by my wife.
