Bumper Type Question... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-08-2010, 12:32 PM
BrianDlaw BrianDlaw is offline
BrianDlaw is on a distinguished road
Default Bumper Type Question...
Okay, first post/question, so be gentle!
I have not yet had installed or installed a hitch, but my mother is hell-bent on me pulling out a shrubbery that she has. I have a 2009 1500, and it has the hole in the bumper for the assembly. Can I loop the rope or chain through there? Or, is there something else that I can or should be hooking to or looping around? I do not have tow hooks in the front yet, so that is not an option.
Any and all thoughts are appreciated.
Thanks,
Brian
Old 08-08-2010, 12:36 PM
I'd loop it over or through a frame hole at the rear and make sure you put a rag around the chain where it passes under your rear bumper.
Don't loop it over the bumper bracket to the frame. It may bend the bracket and your bumper will end up being crooked or dropped to one side.
Don't put it in the hole in the bumper...you'll scratch the bumper and the hole wasn't put there for that.
Just crawl under the truck and find a spot on the frame you can hook into, probably near where you would mount a receiver hitch to the frame rail.
Old 08-08-2010, 12:47 PM
Thanks. I will take a look!
B
PS- Hitch is on the "to do" list, but the step bars were more of a priority (the 5 year old needed to get a running start) and the tri-fold cover was a priority too. Those are done, so time to move on!
Old 08-08-2010, 12:48 PM
Good luck with the shrubbery!
I need more luck with my mother!
Old 08-08-2010, 12:51 PM
Can't help ya with that....
Old 08-08-2010, 03:45 PM
Rep:4358
Looks like you're getting some good advice here, but welcome to the forum! Be sure to introduce yourself to everyone in the Newbie Checkin when you get a chance and get your official Ram Z welcome!
Old 08-08-2010, 06:07 PM
1badram's Avatar
1badram 1badram is offline
Vehicle: 2009 dodge ram 1500
Trim Level: Bighorn
Rep:22
1badram is on a distinguished road
Just rap the chain around the rad support and have at her lol
2009 Dodge Ram 1500 SLT Bighorn 4x4 5.7l hemi
Old 08-26-2010, 02:43 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
If you haven't done this yet, get a tow strap with loops on the ends instead of a chain. Then get a clevis shackle that will fit inge of the holes on the frame. Chains can be dangerous if you haven't worked with them before, they can break and send metal parts flying. I saw one go through the window of a caterpillar truong to pull out a stump, nearly took the drivers head off. A strap is nylon, if it breaks it is pretty harmless.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 08-26-2010, 02:54 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
I would take that (sheet metal) bumper off the reinforcement will stay and loop it around that the bumper is only 6 bolts and 3 connections I can have mine off in 3 minutes much better than bending that bumper..
