Old 08-10-2010, 11:20 AM
Daniel5122's Avatar
Daniel5122 Daniel5122 is offline
Vehicle: 10 Ram 1500 Crew Cab
Trim Level: SLT Big Horn 4X4
Color: Mineral Gray
Daniel5122 is on a distinguished road
Default Thinking of purchasing a travel trailer
I have been looking around the rv dealerships in my area and I think I have narrowed my search down. I am looking at a North Trail NT31BDSS with a dry weight of 6740 and a gross weight of 8600. The hitch weight is 880lbs, and I will definatly go with a weight distribution system. Anyone have any thoughts or experience on how this setup should tow? I have the towing package and the 3.92 gears but I do not have the factory brake controller installed yet, I plan on ordering one next week. I have read that there is some issues installing the controller, but I have verified that I do have the 2 plugs under my dash...so hopefully no problems there.
Anything worth shooting is worth shooting twice. Ammo is cheap. Life is expensive.
Old 08-10-2010, 12:56 PM
blue09's Avatar
blue09 blue09 is offline
Vehicle: 2012 Ram 1500cc
Rep:19
blue09 is on a distinguished road
Default hope i can help
in resonse to your towing questions:
I have a 2009 truck the same as yours with the same rear gears, and tow a travel trailer that weighs about 7000 lbs with gear and a 750 lb tongue weight. The trailer towed fine with a weight distributing system. I added airbags in the rear coils and could not beleive how much better it towed. I reccommend buying Airlift bags for your truck part #60818.
Here is a link http://www.suspensionconnection.com/...-air-bags.html
You will not be dissapointed
Old 08-10-2010, 02:04 PM
Daniel5122's Avatar
Color: Mineral Gray
Do you have the compressor, or are they just a fill once kind of a thing?
Old 08-10-2010, 02:18 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
WoW,just watched the video for the install of the air bag's. So easy & should make a huge difference
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 08-10-2010, 04:08 PM
blue09's Avatar
Rep:19
i do not have the compressor. I use a bike pump to fill the bags as they only hold 35 psi max. Using a bike pump lets you tweak them to the pressure you want easier. I plumbed the bags seperatly to avoid side to side air sloshing when the lines are teed together. using a compressor is tough as you always pass what you want in psi.
Old 08-14-2010, 02:04 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
An air bag alternative worth checking out is the Timbre SES kit.
http://www.timbren.com/ses-kits.htm
Installation - about 10mins.
brad
Interested in one of my mods?
Old 08-14-2010, 12:58 PM
There's a good source for just starting out in the travel trailer arena.
Check out this site:
http://www.rvnetwork.com/index.php?act=idx
The folks there are very helpful!
Old 09-08-2010, 08:51 PM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:26
ken99 is on a distinguished road
Here is an excellent discussion, if not the best, about installation of the factory ITBM:
http://www.ramforumz.com/showthread.php?t=52410
Netman66 did a good job of documenting the install.
Old 09-08-2010, 11:29 PM
Chubby Bruiser Chubby Bruiser is offline
Vehicle: 2010 Quad Cab
Color: Blue
Rep:84
Chubby Bruiser will become famous soon enough
I have a 32 foot 10700 lb Hornet. I had my RV dealer install a Reese tow package with sway bars. They also installed the trailer brake controller. I watched the guy install the controller and it took him less than five minutes. They also leveled the Ram while hitched to the trailer. I pulled it up I-90 about 40 miles two weeks ago and my Ram pulled it like a champ. i was hitting 65 mph at just over 2k rpm. The professional install of the Reese equipment and leveling was well worth the money.
Westin Nerf Bars, Mopar Chrome Bug Deflector, Mopar Mud Flaps, Mopar Slush Mats, Chubby Antenna, K&N Drop in Air Filter, Bosch Wiper Blades, Weathertech Vent Visors, Mopar Trailer Brake Controller, Reese Tow Package with Anti Sway Bars, B Pillar Black Tape Removed, Mopar Chrome Gas Door, Mods to come - 14 inch Mufflex, CAI, Headers, Michelin Tires, Chrome Bed Rails.
Old 09-13-2010, 05:53 PM
Daniel5122's Avatar
Color: Mineral Gray
Thanks for the info! I still haven t pulled the trigger on the trailer purchase, but it is good to know that it will pull well. I have looked around at a few models but I still come back to the North Trail.
