Old 08-10-2010, 02:06 PM
markj's Avatar
markj markj is offline
Vehicle: Ram 1500 1996 Magnum 5.9L
Color: Metallic Black
markj is on a distinguished road
Default Ram 1996, Cant start, help.
Hi all,
I had my 96 Ram parked for about six, months and then decided to put it back on the road.
After driving it for a while it started to develope a problem starting. Basically from cold or first start of the day it would take about 5 to 8 swings to get it to start, then for the rest of the day it would start first time every time.
Unfortunately this deteriorated to point now where I cant get it to start at all.
I read up and determined it was the check valve in the fuel pump module, maybe it was stuck and preventing ful from reaching the fuel rail so i dropped the tank and took out the pump assembly checked it and tested it, all was fine. I Check the fuel at the rail and it was squirting out beautiful.
At this stage I realised that when turning on the ignition there was no "Engine check " light illuminated. So I called in a friend who has a scan tool.
The scan tool was reading, "No communication" which is strange.
So does anyone have any advise please.
Old 08-10-2010, 02:08 PM
Rep:1890
You need to determine why there is no PCM communication. Start by checking all the fuses.
Old 08-10-2010, 04:37 PM
markj's Avatar
I did that, and all were fine, i even switched around the ASD relay. My friend who had the scan tool said, that he thought it might be the computer gone down, which i hope it isnt. Any more advice would be appreciated.
