Old 08-10-2010, 06:23 PM
HerRam's Avatar
HerRam HerRam is offline
Rep:567
HerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to all
Default Question?
ok I have only had my ram for a couple of weeks and I am just wondering if anyone else has had problems with the TPMS? (Tire Pressure Monitoring System)
Everytime I start the truck, I get the 'Low Tire' that flashes across the EVIC and that's it. Is it suppose to stay there when there is a low tire?
It has been doing this since the first week I owned it...and the tire pressures were fine...I don't know if this is a possible problem or normal...any help?
http://i307.photobucket.com/albums/nn293/angelgirl3_23/Snowpics008-2.jpg
Mods to my Pavement Pounding Princess :
K&N drop in filter, 'stubby' antenna and
PINK FUZZY DICE!!!
Old 08-10-2010, 06:24 PM
Rep:1885
What are your actual tire pressures?
Old 08-10-2010, 06:25 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
When you start the truck it will flash briefly then go out assuming the tires are fine.
It is part of the start-up sequence just like all the other lights that flash on the dash.
Brian:
Old 08-10-2010, 07:43 PM
Dodgeramhemi09's Avatar
Dodgeramhemi09 Dodgeramhemi09 is offline
Vehicle: 2009 Dodge Ram 1500 CrewCab
Trim Level: SLT BIG HORN
Color: Deepwater Blue Pearl
Rep:51
Dodgeramhemi09 will become famous soon enough
Yes, it is part of the startup bulb check sequence...In cold weather until your tires warm up it may be on for a short time as well....This happened to me once or twice...
Old 08-10-2010, 11:18 PM
You only need to worry about it if it stays on.
Old 08-11-2010, 12:52 PM
HerRam's Avatar
Rep:567
You guys rock! thankyou I was about to call the place I bought it from and rip them a new one LOL IO had Nitrogen put in them last week being as they charged me for it and I never got it...now I get it back and I am still getting the low tire light upon start up...I thought something was wrong...
Thanks guys!
PINK FUZZY DICE!!!
