Old 08-10-2010, 08:16 PM
Small Hauler Small Hauler is offline
Small Hauler is on a distinguished road
Default 2001 Ram 1500 Sport 4X4 Diff Question
Hey Guys, My Equipment ID Decal in the Glove Box states that I have a DRB 3850 Corp Rear Axle and under that is DSA Axle -Anti Spin Diff. Do I need to use the MOPAR Friction Modifier when I change the Diff Lube? Is Anti-Spin the same as the old Limited Slip? My truck has the Off Road Package.
Old 08-10-2010, 08:21 PM
Rep:1885
Yes and yes. You need 4 oz. of additive for the rear diff.
Old 08-10-2010, 08:28 PM
That's good to know, Randy! I wondered what the corporate ID was on the limited slip and if it needed the friction additive. Cool...
Old 08-10-2010, 08:32 PM
Rep:1885
I'm not sure that the codes would be the same for your truck, Michael. Did I ever send you the build sheet on yours?
Old 08-10-2010, 08:37 PM
Yes, you did. Let's see...
DMES3.73 Axle Ratio
DRWS10.50 Rear Axle
DSAAnti-Spin Differential Rear Axle (ugh..no burnouts...LOL)
Old 08-10-2010, 09:00 PM
A word of advice . Stay on top of servicing the rear diff . Do it every 15,000 miles (it think thats what they recommend) . If you don't the clutch pack will break apart and chew up the bearing cap and housing and maybe even chew up the gear . I'm talking from experience . I'm sure Randy can vouch for that also . My dealer knew exactly what I was talking about when I called them . I thought it was a crock to service it that frequently . Boy was I wrong . $650.00 later for a used rear .
