Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 08-11-2010, 04:56 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
Default Dead spot in gas pedal
My truck always had a dead spot in the pedal where it seemed like if I didnt floor it nothing was gonna happen. I got my SC tuner and that fixed most of it, but now I feel like its back and even worse at times. While on the highway if I wanna speed up I have to press the pedal 3/4"-1" to get it to downshift and speed up like 5mph. WTF!!!!!
Old 08-11-2010, 05:18 PM
Try cleaning the throttle body.
Old 08-11-2010, 05:20 PM
mattg1500's Avatar
Rep:22
just did and had a fuel system cleaning done. Its spotless
Old 08-11-2010, 05:27 PM
So it bogs or just doesn't do anything in this "dead spot" ?
Are you in D or O/D?
Old 08-11-2010, 06:10 PM
mattg1500's Avatar
Rep:22
It doesnt bog it just acts like im not even pressing down on the pedal, and when it finally says "O I should be doing somthing" it downshifts and takes off and alls I want to do is close the gap between me and the guy in front of me, not run him over. Its in D I cant choose OD. If i put tow haul on it just revs higher and takes off everytime I hit it, no problems there.
Old 08-11-2010, 06:19 PM
I kinda have the same problem. I haven't been able to dial it out with the Predator and it has me kinda stumped. I cleaned my TB (it needed it) and it seemed to be better but not by much.
Old 08-11-2010, 06:26 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Mine does the same at hwy speeds....
Old 08-11-2010, 06:37 PM
mattg1500's Avatar
Rep:22
That sucks. My TB was bad also but I try and clean it whenever I clean my filter. Can the TPS sensor be dirty?
Old 08-11-2010, 07:17 PM
Garbageman's Avatar
Garbageman Garbageman is offline
Vehicle: 2010 1500 ST Quad Cab 4x2
Trim Level: Really cheap
Garbageman is on a distinguished road
Sounds like a Transmission issue not a fuel system issue. If it will work fine in tow mode then it is not detecting the signal to down shift properly.
With out the down shift the motor will not rev. Since your in an overdrive gear crusin the motor is spining almost half as many RPMs as the rear tires. I'm not to sharp on the Chysler overdrive transmisions but I think they are electric over hydralic systems so your best bet would be the transmission shop.
Old 08-11-2010, 07:59 PM
mattg1500's Avatar
Rep:22
Its also got a new trans and TCM. It did the same thing with the other 3 trannys also, beore I blew them the F up!
