Old 08-14-2010, 10:02 AM
Mattones's Avatar
Mattones Mattones is offline
Vehicle: 2009 Dodge Ram 1500 SLT Quad
Rep:164
Mattones has a spectacular aura aboutMattones has a spectacular aura about
my truck is at 35,700KM's and I need new tires by Oct.
2009 Dodge Ram 1500 4x4 5.7 Hemi Quad Cab
Cat Back Magnaflow Exhaust stainless, Tinted Front Windows, Painted Engine Cover, Red Calipers, LED Reverse Lights, Lightbar and 4 Hella 500
Old 08-16-2010, 08:01 AM
FDBDW's Avatar
FDBDW FDBDW is offline
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
HI-JACK ALERT
What brand and model tire is the best for our trucks
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 08-16-2010, 10:33 AM
Rep:1625
Originally Posted by FDBDW View Post
HI-JACK ALERT
Are you looking for a mud-terrain or an all-terrain?
Old 08-16-2010, 11:11 AM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
Factory tires suck.
The firestones on my caliber were un safe to me at 25000km
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 08-16-2010, 04:09 PM
DIVERMAN's Avatar
DIVERMAN DIVERMAN is offline
Vehicle: 2010 Ram 1500 4X4
Trim Level: SLT BigHorn
Color: Inferno Red/Tan
DIVERMAN is on a distinguished road
10k is too long to go with out rotating them. should be done at every oil change. go to a goodyear store, they will do it for free. i rotate mine every 3k. and you should algin the front end every year whether you think it needs it or not. it takes a beating. everyone has there own likes and dislikes about everything. but, if you don't take care of something, no matter what brand it is, it's not going to last.
2010 Ram 1500 4X4 CC SLT BigHorn 5.7L 3.55 Gears INFERNO RED, NAV/ALPINE,5" StepBars,Dual Exhaust.
Old 08-21-2010, 04:51 PM
XxCRAZYBUDxX XxCRAZYBUDxX is offline
Vehicle: 2009 DODGE RAM 1500 4X4
Trim Level: LARAMIE
Color: DEEP WATER BLUE 2TONE
XxCRAZYBUDxX is on a distinguished road
Originally Posted by tbagr09hemi View Post
Have an 09 1500 Laramie, 36,200 miles, that came with the goodyear tires. Took to dealer for my third tire rotation in May and was experiencing shaking and "cupping" of tires. Rotated and balanced. Took back a couple weeks later cause still shaking a bit, they said they adjusted the camber (spelling?). Two months later, no shaking but front tires are "feathered" worse than back and one of the back tires is worn to wear bar....need new tires already!! Took to tire specialty store and had Michelin LTX M/S 2.....GREAT tire, better ride than original.
FYI, "Adjustment of wheel alignment alone will seldom cure the problem. Any worn component that connects the wheel to the car (ball joint, wheel bearing, shock absorber, springs, bushings, etc.) can cause this condition. Worn components should be replaced with new ones. The worn tire should be balanced and possibly moved to a different location on the car. Occasionally, wheels that are out of balance will wear like this, but wheel imbalance usually shows up as bald spots between the outside edges and center of the tread."
Showed this to the dealer and they would not back up their service and replace tires.
i HAD THE SAME ISSUE,Dealer said everything was still in line CUPPING and FEATHERING of front tires,i had no shaking.so what i did was looked at every new ram i saw parked and noticed they all was doing this...
IT only went bad to a certian point...
im sure it was just this speciacial desighned tire for the dodge ram for the 1500 to smooth the ride the best it could be... that amount of miles is about all the tire should be safe for for normal wear and tear.I did have the truck looked @ buy n2 other proff. locations and same verdict it the tires not the truck...
