Old 08-12-2010, 03:23 PM
miller2013's Avatar
miller2013 miller2013 is offline
Vehicle: 2008 Ram 1500
Trim Level: Quad Cab- Lone Star
Rep:87
miller2013 will become famous soon enough
Default Painting Rims maybe but need some help?
ok so i am looking to paint my rims but i really have no idea what to do and if it will work on my rims? So i would appreciate some help! hope the following pic can help you help me!!
-Flowmaster Super 40 -S&B CAI -55W DDM HID Kit -Tow Mirrors -Hopefully more to come soon!
Old 08-12-2010, 03:58 PM
Well if it were me , I would wash the wheels and tires real good . Looks like you have some shiny stuff on the tires . I'm sure it's on the wheels also . That will hinder the primer and paint from sticking . Prep sol the wheels to remove any other contaminants . Scuff the wheels down with some sand paper , knock the shine off . Tape off the wheels , prime and let dry . Take a good look and make sure the prime job looks good . They spray the color on . At this point let it dry real well . It's up to you , I would throw a couple of coats of clear on them also .
Old 08-12-2010, 07:50 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
Just a couple of things to add to what Tom said. Use 320-400 grit sandpaper anything courser will leave scratch marks. One product I've used with pretty good luck is Dupli-color, it's a lacquer which is a pretty forgiven paint. Just one thing be sure and shake the can and make sure the rattler works, they seem to have a problem with that.
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
Old 08-12-2010, 09:02 PM
I push the skinny pedal
Rep:3308
I'd also like to recommend using an self-etching primer. I know it's a coated wheel, however, after sanding it, you'll want to make sure you have as much adhesion as possible, so the self-etching primer will make a great addition to the adhesion. Duplicolor makes a good one, and combine it with either their regular auto paint (which is laquer based) or you can use their enamel wheel paint, which will give you a harder coating.
Kurtis
Old 08-13-2010, 11:36 AM
miller2013's Avatar
Rep:87
I have heard i do not need to use primer i can just wash, sand, wash, rubbing alcohol, paint (a few coats), and clear coat?
Old 08-13-2010, 04:54 PM
RamItAll's Avatar
RamItAll RamItAll is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
Rep:85
RamItAll will become famous soon enough
deffinately use primer if you want the paint to last. everything they have said so far is exactly correct. as for keeping paint off the tires. put sheets of news paper between wheel and tire and/or playing cards work great too. then after painting you can clearcoat or not. whatever your decision is. BTW what color are you doing?
Old 08-13-2010, 05:12 PM
miller2013's Avatar
Rep:87
i was planning on doing either black or grey since my truck is black i think black is the way to go but i want the glossy finish on my rims! Also my tires cover up the lip of my rim and they also have the weights on the lip for balancing what should i do about that??
Old 08-13-2010, 10:49 PM
Rep:1625
Here's some pics I found:
Old 08-13-2010, 10:56 PM
ScatPak07's Avatar
Rep:970
If it were me doing it I would take the tires off and the weights to really get it done perfect. You want to make sure you get everything so it looks good. Especially that the rims are chrome and you want to go black. Definitely use a primer on the wheels to make the paint last longer.
You want to really scuff them up first to allow the primer to hold better. Then after a couple coats of primer spray a couple coats of color. If you want them to shine then go with a few coats of clear coat. The more clear you go the glossier it will be and also the more protection you will have.
Old 08-13-2010, 11:54 PM
miller2013's Avatar
Rep:87
Thanks scat i would love to take off the tires and do it but being in college it would be tough and i have no extra tires to ride on while i am painting them..... Cadet is that guy on the forum?
