Old 08-13-2010, 12:33 AM
lt173 lt173 is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: SLT Plus
lt173 is on a distinguished road
Default Spare Tire on 2010 1500 Quad with 20's
Quick question fellow Ram lovers. Took possession on July 16/2010. Everything is good. Other day I decide to check the spare and I guess I should have done it earlier. Although I have 20's all around, the spare is a 17 inch. This can't be normal? Contacted the dealership and the rep. says he has to look into it. I simply told him must be a mistake there's no way this can be right. Someone be kind enough to tell me if I'm having a bad dream, or is this the spare I should have. Can't believe it's not supposed to be a 20? Thanks.
Old 08-13-2010, 12:40 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Hmm, I've never looked at the size of my spare. Guess I'll have to do that.
Brian:
Old 08-13-2010, 12:41 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
It's a 17! Haven't checked, but it is likely the same OD as the 20's.
brad
Interested in one of my mods?
Old 08-13-2010, 12:50 AM
Yeah that's my thoughts, I mean wouldn't the 17 have to spin faster causing diff issues? Thanks for the replies.
Old 08-13-2010, 09:58 AM
jwleo jwleo is offline
jwleo is on a distinguished road
I just noticed the same thing on my truck last weekend. According to my dealership the 17 inch is the correct spare. I was told the 20 inch would not fit in the space under the truck. On the door it even lists the spare tire as a 17 inch tire.
Old 08-15-2010, 11:58 PM
JRye's Avatar
JRye JRye is offline
Trim Level: TRX4
Rep:28
JRye is on a distinguished road
Dodge calls the 17" spare "Full size restricted use spare". It's used for those with 20" wheels.
I have 17's so my spare is the exact duplicate of the rest of my tires.
Old 08-16-2010, 12:11 AM
Color: RootBeer
Rep:1287
If the outside diameter of the tire is the same as the other tires, there will be no mechanical effect of having a 17" wheel.
However, if the tire is smaller and you have to use it, best to get it off the truck ASAP because it will turn at a different rate than the other tires.
Brian:
Old 08-16-2010, 01:27 PM
NDNICK NDNICK is offline
Vehicle: 2009 DODGE RAM
Color: WHITE
NDNICK is on a distinguished road
My truck had 17" inch wheels on it and i put on the stock 20" wheels.
I took off the factory 17" spare and my brother had a 20" spare off his old
2006 ram i put under with no fitment problems. It's probably cheaper for
dodge to use the 17" spare instead.
Old 08-23-2010, 02:31 AM
dweir246 dweir246 is offline
dweir246 is on a distinguished road
Wheel size doesn't matter as long as the tires are the same diameter.
Old 08-23-2010, 08:42 PM
Fury's Avatar
Fury Fury is offline
Vehicle: 2010 Dodge Ram Crew Cab 2WD
Color: Mango Tango Pearl
Rep:103
Fury will become famous soon enoughFury will become famous soon enough
Well, this is a bummer. Just checked mine and its a 17. Even if it was a 20 inch it wouldn't look the same as the rims that are on now. I would get the tire fixed ASAP anyways.
This is the one thing that I've noticed about the Ram the cheapness in the wheels.
2010 Ram 1500 Crew Cab Sport, NAV, Alpine, Rear Cam, Remote Start, Performance Hood, Mopar Side Steps, Adjustable Pedals, Leather Bucket Seats.
Mod: DSP, 14" Magnaflow
